Home » Eclipse Projects » Remote Application Platform (RAP) » Resource Plug-in in RAP Target platform
Resource Plug-in in RAP Target platform [message #538109] Sat, 05 June 2010 01:36 Go to next message
Hi All,
I had some dependencies to the Resource plug-in.But i do see the RAP runtime does not contain the RAP plug-ins.
Do i have to then manually keep the dependency of the Resource plug-in from other targets ?.
Thanks and Regards,
Saurav
Re: Resource Plug-in in RAP Target platform [message #538134 is a reply to message #538109] Sat, 05 June 2010 10:19 Go to previous messageGo to next message
ok...my mistake i could never think in the lines of RAP...may be a beer will help here...
My use case would need my web application to access the local file system.I dont think RAP has a functionality where in i can visualize an Eclipse workspace kind of thing in user's system.Hence the unavailablity of the Resource plug-in.
Then do i need to use the Java IO to access the local file system?.
Any plans for leveraging the Resource plug-in of the EFS in RAP ?
Re: Resource Plug-in in RAP Target platform [message #538511 is a reply to message #538134] Mon, 07 June 2010 15:33 Go to previous messageGo to next message
> will help here...
> system.
There is no way to access the local file system without special
plug-ins, applets or similar things. The browsers security policy
prevent Javascript code from doing so.
We do not provide the resource plug-in because it is not suitable for
general-purpose use in a multi-user-environment. There might be
use-cases in which it makes sense to use the resource plug-in. In such
cases you will have to add it to the target by yourself. When doing so,
always bear in mind that *all* users/session will then access *one*
single workspace.
With java.io you will still be accessing the servers file system.
HTH
Rüdiger
Re: Resource Plug-in in RAP Target platform [message #539144 is a reply to message #538109] Wed, 09 June 2010 14:35 Go to previous messageGo to next message
Hi Rudiger,
Many thanks for the answers provided above.
Please find my comments/questions quoted with below.
I agree
single workspace.
I thought i could not add anything in my target.
Please clear my understanding.If i add the resource plug-in my target.Would it not create problem while creating/deploying the war in the server ?.
I agree.I have gone the Java I/O way.
The last question still remains i.e. any plans of leveraging the resource concept of EFS in the RAP ?.
Again many thanks for the answers.
cheers,
Saurav
Re: Resource Plug-in in RAP Target platform [message #539153 is a reply to message #539144] Wed, 09 June 2010 14:50 Go to previous message
On 09.06.2010 20:35, saurav wrote:
> Hi Rudiger,
> Quote:
> I agree
> Quote:
>> single workspace.
> the server ?.
Apart from the already mentioned fact that the resource plug-in isn't
multi-user-aware, it won't cause problems.
Please make sure that you have a good understanding of the underlying
technologies of RAP. In particular OSGi and how to work with it in PDE.
Here are some links to further information:
http://www.eclipse.org/rap/documentation.php#resources
http://eclipse.org/pde/
> Quote:
As said before, the resource plug-in (and as such EFS as it is used by
the resource plug-in) is of no general use in a multi-user environment.
Therefore there are no plans to integrate it in RAP. However, this
doesn't prevent you from using it in a RAP Environment. The only thing
is, it doesn't come with RAP out of the box.
> cheers,
> Saurav
HTH
Rüdiger
Previous Topic:Does RAP support implementing a console?
Next Topic:[ Titanic ] java.net.SocketException: Too many open files
Current Time: Sat Sep 13 01:13:41 EDT 2025
Powered by FUDForum. Page generated in 0.04604 seconds
