Home » Archived » Test and Performance Tools Platform (TPTP) » Unexpected end of ZLIB input stream
Unexpected end of ZLIB input stream [message #53913] Thu, 16 February 2006 12:10 Go to next message
Originally posted by: vgurov.evelopers.com
Hi, TPTP Team!
First of all, thanx a lot for a great tool!
I'm tring to profile my jboss application.
Eveything works fine for 5-10 seconds, but then status bar (events
processed) freeze.
Start Monitoring, Pause Monitroing - no reaction. Actually it gathers a
little bit of profile info, but...
I've started eclipse with java console and found the following exception.
I'm sure it's the cause. But how to avoid it?
My config is:
TPTP 4.1.0.1
Eclipse 3.1.2
EMF 2.1.2
XSD 2.1.1
GEF 3.1.1
JDK 1.5.0_06-b05
WinXP SP2
java.io.EOFException: Unexpected end of ZLIB input stream
at java.util.zip.InflaterInputStream.fill(Unknown Source)
at java.util.zip.InflaterInputStream.read(Unknown Source)
at java.util.zip.ZipInputStream.read(Unknown Source)
at
org.eclipse.hyades.trace.ui.internal.piclient.XMLTraceDataPr ocessor.copyZip(XMLTraceDataProcessor.java:291)
at
org.eclipse.hyades.trace.ui.internal.piclient.XMLTraceDataPr ocessor.makeWriter(XMLTraceDataProcessor.java:225)
at
org.eclipse.hyades.trace.ui.internal.piclient.XMLTraceDataPr ocessor.createWriter(XMLTraceDataProcessor.java:203)
at
org.eclipse.hyades.trace.ui.ProfileUIManager.startMonitoring (ProfileUIManager.java:123)
at
org.eclipse.hyades.trace.ui.internal.actions.StartTraceActio nDelegate.doAction(StartTraceActionDelegate.java:34)
at
org.eclipse.hyades.trace.ui.internal.actions.AbstractProfile ActionDelegate$1.run(AbstractProfileActionDelegate.java:101)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.hyades.trace.ui.internal.actions.AbstractProfile ActionDelegate.run(AbstractProfileActionDelegate.java:96)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Unexpected end of ZLIB input stream [message #53953 is a reply to message #53913] Fri, 17 February 2006 10:26 Go to previous message
Hi Vadim,
It looks like you are profiling to a file, try to use a different target
file name for each launch in your Profile launch configuration ->
Profiling -> Destination tab, see "Send the profiling data to a file"
check-box. After you profile to a file you will need to import that file
(you can also use filters at import time to reduce the amount of data
that you load in memory).
If you want to see the data as it is received just uncheck the above
check-box and relaunch the application in profile mode.
--Marius
Vadim Gurov wrote:
> Hi, TPTP Team!
> processed) freeze.
> My config is:
> TPTP 4.1.0.1
> Eclipse 3.1.2
> EMF 2.1.2
> XSD 2.1.1
> GEF 3.1.1
> JDK 1.5.0_06-b05
> WinXP SP2
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Exporting UML2 Trace Interactions
Next Topic:RAC and JUnit deployment
Current Time: Tue Oct 21 07:14:50 EDT 2025
Powered by FUDForum. Page generated in 0.03546 seconds
