Home » Modeling » GMF (Graphical Modeling Framework) » how to make an element undeletable
how to make an element undeletable [message #538534] Mon, 07 June 2010 17:38 Go to next message
For some reasons I want to make one element non deletable once created,
Is there a way to do that ?
Re: how to make an element undeletable [message #538545 is a reply to message #538534] Mon, 07 June 2010 18:17 Go to previous messageGo to next message
you can try to override the getDestroyElementCommand() method of the
ItemSemanticEditPolicy of the corresponding node edit parts.
protected Command getDestroyElementCommand(DestroyElementRequest req) {
return UnexecutableCommand.INSTANCE;
For links use getDestroyReferenceCommand() accordingly. Note that this
includes that the parent edit part can not be deleted, too.
Maybe you need to additionally install another policy to prevent deletion by
the del key also:
installEditPolicy(EditPolicy.COMPONENT_ROLE, new ComponentEditPolicy() {
protected Command getDeleteCommand(GroupRequest request) {
return null;
HTH
Axel
Re: how to make an element undeletable [message #538856 is a reply to message #538545] Tue, 08 June 2010 15:44 Go to previous messageGo to next message
I tried but I had the following compile error:
Type mismatch: cannot convert from UnexecutableCommand to Command
even casting does not work.
Any idea ?
Re: how to make an element undeletable [message #539109 is a reply to message #538534] Wed, 09 June 2010 12:04 Go to previous messageGo to next message
be careful with command: some are emf, other gef or gmf. So check carefully the right type of the UnexecutableCommand
Re: how to make an element undeletable [message #539162 is a reply to message #538534] Wed, 09 June 2010 15:40 Go to previous messageGo to next message
Thanks Aurelien,
I tried it and works perfectly.
Re: how to make an element undeletable [message #539450 is a reply to message #539162] Thu, 10 June 2010 14:32 Go to previous messageGo to next message
I have one problem when deleting using the key:
THE element itself is not deleted but its children were deleted.
Re: how to make an element undeletable [message #539997 is a reply to message #539450] Mon, 14 June 2010 10:26 Go to previous messageGo to next message
Now it works fine.
But I need to make the Delete from Model popup menu disabled for this element. Any idea on how to do that ?
Re: how to make an element undeletable [message #540025 is a reply to message #538534] Mon, 14 June 2010 11:54 Go to previous message
I have found the answer through this good link:
http://www.jlab.net/Jboard11/JBoard.jsp?action=read&inde x=610&page=2&tale=0&tablename=eclipsedev&way =0&maxrow=18&searchtype=&keyword=&category=
Previous Topic:Migration to GMF 2.3: issue with Editpolicy and move/reparent
Next Topic:Exceptions with Palette since 3.6 RC3
Current Time: Tue Dec 02 09:59:11 EST 2025
Powered by FUDForum. Page generated in 0.05109 seconds
