ATF Debugging question [message #538863] |
Tue, 08 June 2010 15:55  |
I'm trying out ATF, and I have an HTML file that I included into a project through Eclipse. When I debug through Mozilla, it doesn't use the breakpoints that I entered into the editor. I need to load up the source file (by double clicking on the file in scripts) and put in the breakpoints in that file.
Should the debug in Mozilla detect these breakpoints? Also I need to actually run the HTM file from a full URL (since my script includes are coded for that), so I won't be able to use the Project File option to run (and will need to use URL), will that support loaded breakpoints?
Arin
Re: ATF Debugging question [message #544138 is a reply to message #543857] |
Thu, 01 July 2010 13:29  |
By : "since my script includes are coded for that" I mean that the <script src=xxx > points to the location on the Web server, which is not the same as the file system
By: "will that support loaded breakpoints" I mean that I want to put a breakpoint in foo.htm and when I run http://blah/foo.htm I want that breakpoint to be active instead of needing to open the source of the "downloaded" file and put the breakpoint in that version, and then reload the page.
Arin
FUDForum. Page generated in 0.05405 seconds
