Starting Equinox OSGI environment [message #538712] |
Tue, 08 June 2010 09:16  |
Hi All,
I'm trying to start Equinox programatically but I get the following error:
at
org.eclipse.osgi.internal.baseadaptor.BaseStorage.readStateD ata(BaseStorage.java:743)
at
org.eclipse.osgi.internal.baseadaptor.BaseStorage.getStateMa nager(BaseStorage.java:698)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.getState(BaseAdapto r.java:390)
at
org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:307)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518)
at
org.eclipse.osgi.framework.internal.core.Framework$6.run(Fra mework.java:1473)
at java.security.AccessController.doPrivileged(AccessController .java:197)
at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1471)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
at
test.com.ibm.db2pm.server.statementtracker.zos.plugin.OsgiSe rverConnector$1.run(OsgiServerConnector.java:77)
It seems that the context is null at that position
(BaseStorage.java:743) but I cannot set the context because
EclipseStarter.startup() is creating one and returning it to me.
I'm pretty sure that I missed something somewhere. The following code
snipped shows my code:
System.setProperty("osgi.parentClassloader", "fwk");
System.setProperty("org.osgi.framework.bootdelegation", "*");
System.setProperty("osgi.compatibility.bootdelegation", "true");
System.setProperty("osgi.clean", "true");
System.setProperty("osgi.install.area", "...");
System.setProperty("osgi.configuration.area", "...");
System.setProperty("eclipse.ignoreApp", Boolean.toString(true));
System.setProperty("eclipse.consoleLog", Boolean.toString(true));
EclipseStarter.startup(new String[] {"-noconsole"}, null);
Thanks in advanced
arens
Re: Starting Equinox OSGI environment [message #538770 is a reply to message #538712] |
Tue, 08 June 2010 10:56  |
Just an update:
I should have said before that I try to start Equinox from an ANT script
that I start from within Eclipse. When I try to start Equinox using a
JAVA task with fork=true Equinox starts without any problems. That's why
I think that it has something todo with the fact that my IDE and the
Equinox I try to start share the same JVM. May this be the case? If yes,
can I force Equinox to create a new/separate Context?
arens
FUDForum. Page generated in 0.03754 seconds
