Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Aligning widgets within different composites
Aligning widgets within different composites [message #538607] |
Tue, 08 June 2010 04:03  |
Hello all
Say I have a form with 3 columns.
I want to group say the bottom two rows into an SWT Group widget.
How do I tell the bottom two rows that they have to have the same column
size as the columns above, when they belong to a different parent and have a
different gridlayout object?
Poorly drawn ASCII example:
x x
x x
x x
yy yy
yy yy
The y's are the grouped widgets. They have their own GridLayout (set on the
Group composite). I want the column width to be the same for both sets of
widgets, e.g
x x
x x
x x
yy yy
yy yy
Thanks!
Greg
Re: Aligning widgets within different composites [message #538650 is a reply to message #538644] |
Tue, 08 June 2010 06:38   |
the double y represent a composite containing two buttons....
i understand that..now after seeing between the lines,the solution would be
package org.eclipse.swt.snippets;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Shell;
public class Snippet
static Display display;
static Shell shell;
public static void main(String[] args)
display = new Display();
shell = new Shell(display);
shell.setSize(300, 300);
shell.open();
shell.setLayout(new GridLayout(5, true));
for (int i = 0; i < 15; i++)
Button button = new Button(shell, SWT.PUSH);
button.setText("B" + (i + 1));
GridData layoutData = new GridData();
layoutData.grabExcessHorizontalSpace = true;
button.setLayoutData(layoutData);
Composite composite = new Group(shell, SWT.NONE);
composite.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
composite.setLayout(new GridLayout(2, false));
Button button = new Button(composite, SWT.PUSH);
button.setText("B16");
Button button1 = new Button(composite, SWT.PUSH);
button1.setText("B17");
composite.setLayoutData(layoutData);
Composite composite1 = new Group(shell, SWT.NONE);
composite1.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
composite1.setLayout(new GridLayout(2, false));
GridData layoutData1 = new GridData();
Button button11 = new Button(composite1, SWT.PUSH);
button11.setText("B16");
Button button12 = new Button(composite1, SWT.PUSH);
button12.setText("B17");
composite1.setLayoutData(layoutData);
shell.layout();
while (!shell.isDisposed())
if (!display.readAndDispatch()) display.sleep();
display.dispose();
changing
to
GridData layoutData = new GridData(GridData.FILL_HORIZONATL);
also would be what u want...
[Updated on: Tue, 08 June 2010 06:40] by Moderator
Re: Aligning widgets within different composites [message #538665 is a reply to message #538650] |
Tue, 08 June 2010 07:32   |
You'll notice in this example the columns are aligned with the group, not
the button within the group.
I need to align the widgets (buttons in this example) in the groups, to the
widgets in another control (for example the parent composite, the section
above the groups in the example).
Here is a diagram of what I am trying to achieve:
y y
| x x |
The y's need to be aligned with the x's in the group.
Let me know if you do not understand the question.
"vijay" <vijay.rajonline@gmail.com> wrote in message
news:hul6io$53c$1@build.eclipse.org...
> be
> import org.eclipse.swt.widgets.Display;
> static Shell shell;
> shell.open();
> true));
> true));
> shell.layout();
> display.dispose();
> why, mr. Anderson, why, why do you persist?
> Because I Choose To.
> Regards,
> Vijay
Re: Aligning widgets within different composites [message #538679 is a reply to message #538665] |
Tue, 08 June 2010 08:10   |
ok now i got u r requirement
static Shell shell;
shell.open();
GridData layoutData = new GridData(SWT.CENTER, SWT.TOP, true, false);
// layoutData.widthHint = 20;
GridData layoutData1 = new GridData(GridData.FILL_HORIZONTAL);
layoutData1.horizontalSpan = 2;
composite.setLayoutData(layoutData1);
GridLayout layout = new GridLayout(2, false);
layout.marginHeight = 0;
layout.marginWidth = 0;
composite.setLayout(layout);
button1.setLayoutData(layoutData);
composite1.setLayoutData(layoutData1);
composite1.setLayout(layout);
button11.setLayoutData(layoutData);
button12.setLayoutData(layoutData);
shell.layout();
display.dispose();
this is the closest it can get....
if u want a perfect dynamic match,i think it would not be possible...
by the way i am the same guy answering "Getting column width from GridLayout " query
thats why i told u forget that query concentrate on this one...
(i am just trying to help )
Current Time: Sat Jul 19 03:13:39 EDT 2025
Powered by FUDForum. Page generated in 0.51859 seconds
