Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Getting column width from GridLayout
Getting column width from GridLayout [message #538633] Tue, 08 June 2010 05:11 Go to next message
Hi All,
Is there any way to work out the column width of a GridLayout?
I want to use this later in setting widthHint on GridData.
Thanks heaps!
Greg
Re: Getting column width from GridLayout [message #538645 is a reply to message #538633] Tue, 08 June 2010 06:30 Go to previous messageGo to next message
width hint should only be used if u want width other then the width calculated by gridlayout...
Re: Getting column width from GridLayout [message #538651 is a reply to message #538645] Tue, 08 June 2010 06:32 Go to previous messageGo to next message
The question was "Is there any way to work out the column width of a
GridLayout?"
"vijay" <vijay.rajonline@gmail.com> wrote in message
news:hul63c$bkr$1@build.eclipse.org...
> why, mr. Anderson, why, why do you persist?
> Because I Choose To.
> Regards,
> Vijay
Re: Getting column width from GridLayout [message #538652 is a reply to message #538651] Tue, 08 June 2010 06:49 Go to previous messageGo to next message
thats why if gridlayout has already set the same width,why u want to set the same width using width hint again...
if this question is related to u r previous question the i think u can leave this question!!!!
Re: Getting column width from GridLayout [message #538667 is a reply to message #538652] Tue, 08 June 2010 07:33 Go to previous messageGo to next message
If you can't answer the question, please don't reply.
news:hul77h$kmu$1@build.eclipse.org...
> Quote:
> Regards,
> Vijay
Re: Getting column width from GridLayout [message #538678 is a reply to message #538667] Tue, 08 June 2010 08:09 Go to previous message
am just trying to help
[Updated on: Tue, 08 June 2010 08:10] by Moderator
Previous Topic:Removing columns from viewers
Next Topic:Aligning widgets within different composites
Current Time: Sat Jul 26 10:39:39 EDT 2025
Powered by FUDForum. Page generated in 0.09038 seconds
