Home » Eclipse Projects » Mylyn » Startup time inacceptable
Startup time inacceptable [message #538250] Mon, 07 June 2010 02:22 Go to next message
Hi Mylyn Gurus,
Recently my IDE startet to let me wait almost indefinitely when starting
up. Usually it was about 6 seconds. But now the
org.eclipse.mylyn.context.ui is busy in the spash screen for additional
*2:20* minutes.
I already exported the mylyn data to a zip file, deleted (moved) the
..metadata/.mylyn folder and tried again. No change, the startup time is
still 2:30 minutes, waiting most of the time inorg.eclipse.mylyn.context.ui.
Any ideas what can cause this and what I can do against it?
Cheers
/Eike
Re: Startup time inacceptable [message #538465 is a reply to message #538250] Mon, 07 June 2010 12:45 Go to previous messageGo to next message
Eike, can you try the latest weekly build? We interned a few changes strings
to reduce memory overhead which could affect some loading that happens on
startup but there was also a bug related to focusing in the Project Explorer
that could trigger expensive refreshes.
It would very helpful if you could take a couple of thread dumps when
starting up and post them here or send them to me directly!
Thanks.
Steffen
Eike Stepper wrote:
> Hi Mylyn Gurus,
> *2:20* minutes.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Startup time inacceptable [message #538593 is a reply to message #538465] Tue, 08 June 2010 03:46 Go to previous messageGo to next message
Here is a small bash script I use to do such thread dumps (on UNIX-like systems only):
----- jstackSeries -----
#!/bin/bash
if [ $# -eq 0 ]; then
echo >&2 "Usage: jstackSeries <pid> [ <count> [ <delay> ] ]"
echo >&2 " Defaults: count = 10, delay = 0.5 (seconds)"
exit 1
fi
pid=$1 # required
count=${2:-10} # defaults to 10 times
delay=${3:-0.5} # defaults to 0.5 seconds
while [ $count -gt 0 ]
do
jstack $pid >jstack.$pid.$(date +%H%M%S.%N)
sleep $delay
let count--
echo -n "."
done
----- EOF -----
Hope that helps.
Would this be something for the wiki, Steffen?
Cheers, Jörg
> Thanks.
> Steffen
> Eike Stepper wrote:
>> Hi Mylyn Gurus,
>> *2:20* minutes.
>> Cheers
>> /Eike
Re: Startup time inacceptable [message #538822 is a reply to message #538250] Tue, 08 June 2010 13:34 Go to previous messageGo to next message
With Eike's help we were able to track this problem down. The slow startup
was caused by a preference file that stores editor mementos and had grown
quite large over years of Mylyn usage. I have created an FAQ entry that
describes the symptoms and work-around:
http://wiki.eclipse.org/Mylyn/FAQ#Why_does_startup_of_org.ec lipse.mylyn.context.ui_take_so_long.3F
We are working on a better solution on this bug:
226618: [context] move task-specific editor memento storage out of the plug-
in preference store
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226618
Steffen
Eike Stepper wrote:
> Hi Mylyn Gurus,
> *2:20* minutes.
> Cheers
> /Eike
Steffen Pingel
Re: Startup time inacceptable [message #538826 is a reply to message #538593] Tue, 08 June 2010 13:41 Go to previous messageGo to next message
Good idea. I have created this FAQ entry as a start:
http://wiki.eclipse.org/Mylyn/FAQ#How_can_I_report_a_dead-
lock_or_a_problem_about_a_stalled_UI.3F
Please feel free to amend that and link to your script.
Steffen
>> strings to reduce memory overhead which could affect some loading that
>> happens on startup but there was also a bug related to focusing in the
>> Project Explorer that could trigger expensive refreshes.
> systems only):
> #!/bin/bash
> exit 1
> fi
> pid=$1 # required
> do
> sleep $delay
> let count--
> echo -n "."
> done
> ----- EOF -----
> Hope that helps.
> Cheers, Jörg
>> Thanks.
>> Steffen
>> Eike Stepper wrote:
>>> Hi Mylyn Gurus,
>>> *2:20* minutes.
>>> Cheers
>>> /Eike
Steffen Pingel
Re: Startup time inacceptable [message #539013 is a reply to message #538826] Wed, 09 June 2010 06:26 Go to previous message
Done. Look here:
http://wiki.eclipse.org/How_to_report_a_deadlock#jstackSerie s_--_jstack_sampling_in_fixed_time_intervals_.28tested_on_Li nux.29
Cheers, Jörg
> Steffen
>> systems only):
>> #!/bin/bash
>> exit 1
>> fi
>> pid=$1 # required
>> do
>> sleep $delay
>> let count--
>> echo -n "."
>> done
>> ----- EOF -----
>> Hope that helps.
>> Cheers, Jörg
>>> Thanks.
>>> Steffen
>>> Eike Stepper wrote:
>>>> Hi Mylyn Gurus,
>>>> *2:20* minutes.
>>>> Cheers
>>>> /Eike
Re: Startup time inacceptable [message #601459 is a reply to message #538250] Mon, 07 June 2010 12:45 Go to previous message
Thanks.
Steffen
Eike Stepper wrote:
> Hi Mylyn Gurus,
> *2:20* minutes.
> Cheers
> /Eike
Steffen Pingel
Re: Startup time inacceptable [message #601464 is a reply to message #538465] Tue, 08 June 2010 03:46 Go to previous message
#!/bin/bash
exit 1
fi
pid=$1 # required
do
sleep $delay
let count--
echo -n "."
done
----- EOF -----
Hope that helps.
Cheers, Jörg
> Thanks.
> Steffen
> Eike Stepper wrote:
>> Hi Mylyn Gurus,
>> *2:20* minutes.
>> Cheers
>> /Eike
Re: Startup time inacceptable [message #601468 is a reply to message #538250] Tue, 08 June 2010 13:34 Go to previous message
in preference store
Steffen
Eike Stepper wrote:
> Hi Mylyn Gurus,
> *2:20* minutes.
> Cheers
> /Eike
Steffen Pingel
Re: Startup time inacceptable [message #601471 is a reply to message #538593] Tue, 08 June 2010 13:41 Go to previous message
Steffen
> systems only):
> #!/bin/bash
> exit 1
> fi
> pid=$1 # required
> do
> sleep $delay
> let count--
> echo -n "."
> done
> ----- EOF -----
> Hope that helps.
> Cheers, Jörg
>> Thanks.
>> Steffen
>> Eike Stepper wrote:
>>> Hi Mylyn Gurus,
>>> *2:20* minutes.
>>> Cheers
>>> /Eike
Steffen Pingel
Re: Startup time inacceptable [message #601474 is a reply to message #538826] Wed, 09 June 2010 06:26 Go to previous message
Done. Look here:
Cheers, Jörg
> Steffen
>> systems only):
>> #!/bin/bash
>> exit 1
>> fi
>> pid=$1 # required
>> do
>> sleep $delay
>> let count--
>> echo -n "."
>> done
>> ----- EOF -----
>> Hope that helps.
>> Cheers, Jörg
>>> Thanks.
>>> Steffen
>>> Eike Stepper wrote:
>>>> Hi Mylyn Gurus,
>>>> *2:20* minutes.
>>>> Cheers
>>>> /Eike
Previous Topic:Mylyn 3.4 RC available
Next Topic:Plugin for "Check update" menu item
Current Time: Sun Jul 27 15:29:25 EDT 2025
Powered by FUDForum. Page generated in 0.24499 seconds
