[Acceleo] Main [message #538202] |
Sun, 06 June 2010 07:09  |
Hi, I have some problems understanding how the mt2mtl creates the main entry point:
I had a module with a chain that called 4 templates, class, enum, interface and core.
When doing the mt2mtl it generates this file:
[module main('http://www.eclipse.org/uml2/2.1.0/UML')/]
[import org::acceleo::module::pim::uml21::gen::java::class /]
[import org::acceleo::module::pim::uml21::gen::java::enum /]
[import org::acceleo::module::pim::uml21::gen::java::interface /]
[import org::acceleo::module::pim::uml21::gen::java::validator::core /]
[template public main(c : Class)]
[comment @main /]
[comment Call the file block in 'class' /]
[ classJava() /]
[comment Call the file block in 'enum' /]
[ enumJava() /]
[comment Call the file block in 'interface' /]
[ interfaceJava() /]
[comment Call the file block in 'core' /]
[ validator() /]
[/template]
It gaves me errors when trying to call enumJava, interfaceJava and validator. I think this is because of the:
The problem is that core operates a UML model, enum operates Enumerations, interface operates Interfaces and class (the only one without errors) operates classes.
When doing the mt2mtl I choose generate for metamodel:
And for type:
Class
I tried generating for type "Model" and then all fails except for validator which is applied correctly to model.
How could I fix this? I mean, how can I tell Acceleo to apply class to classes, enum to enumerations, interface to interfaces and validator to model?
Should I generate different main points? Or should I call it on model and search for the classes and enumerations and interfaces present on the model?
Thank you very much!
Re: [Acceleo] Main [message #538299 is a reply to message #538202] |
Mon, 07 June 2010 04:36   |
--------------040408070105080600070809
Daniel,
The main file we generate is but a stub : as you found out Acceleo 3
operates quite differently from Acceleo 2. I'd say the best way of doing
what you wish to is to call your template on Model and iterate to find
the other arguments :
[template public main(m : Model)]
[comment @main /]
[ m.packagedElements()->filter(Class).classJava() /]
[ m.packagedElements()->filter(Enum).enumJava() /]
[ m.packagedElements()->filter(Interface).interfaceJava() /]
[ validator() /]
[/template]
Laurent Goubet
Obeo
> entry point:
> interface and core.
> [comment @main /]
> [ classJava() /]
> [ enumJava() /]
> [ validator() /]
> [/template]
> And for type:
> Class
> model?
> the model?
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040408070105080600070809--
FUDForum. Page generated in 0.06235 seconds
