Home » Modeling » UML2 » InstanceSpecification of a Modeled Class
InstanceSpecification of a Modeled Class [message #537829] Thu, 03 June 2010 15:10 Go to next message
I have been playing with the ExtendedPO2, the example given in "Getting Started with UML2" and I'm trying to create an instance of one of the modeled classes using InstanceSpecification.
What I'm doing is: I create an instance specification, then I create a slot for the property "name", and then to assign a value I'm using the setValue() method, but it requires a StereoType.
Do I have to create a stereotype for the class? or maybe this is not the right approach.
InstanceSpecification is = UMLFactory.eINSTANCE.createInstanceSpecification();
is.setName("supplierInstance");
is.getClassifiers().add(supplierClass);
Slot sn = is.createSlot();
Property name = supplierClass.getAttribute("name", stringPrimitiveType);
sn.setDefiningFeature(name);
//sn.setValue(StereoType, ..., ...)????
Thank you.
Hector
Re: InstanceSpecification of a Modeled Class [message #537859 is a reply to message #537829] Thu, 03 June 2010 17:46 Go to previous messageGo to next message
hi
i guess after adding a slot you have to add some thing literal (right click on slot and choose your value type) whether it is string, integer or instance for example, and then set there your value, is that what you are asking about?
Re: InstanceSpecification of a Modeled Class [message #537866 is a reply to message #537859] Thu, 03 June 2010 18:27 Go to previous messageGo to next message
Hi Wafaa,
Thanks for the replay. I'm trying to achieve a similar result but programmatically, not in the editor. Something like the code I have in my first post.
Hector
Re: InstanceSpecification of a Modeled Class [message #537944 is a reply to message #537866] Fri, 04 June 2010 05:52 Go to previous messageGo to next message
yes, I see.
Sorry I did not see the code Very Happy
but so, can you tell me why do you use code, what is its benefits than editor..(I might ask about the target of programming it)
Re: InstanceSpecification of a Modeled Class [message #538005 is a reply to message #537829] Fri, 04 June 2010 09:25 Go to previous messageGo to next message
Hi, Hector,
Slots have multiple values. Get the value collection:
EList<ValueSpecification> Slot::getValues()
and add some kind of a ValueSpecification to it.
The setValue(Stereotype, ...) method is the API on the Element type that
sets stereotype attribute values. That has nothing to do with your
requirement.
Christian
On 03/06/10 03:10 PM, Hector Chavez wrote:
> Hello,
> right approach.
> Thank you.
> Hector
Re: InstanceSpecification of a Modeled Class [message #538081 is a reply to message #537944] Fri, 04 June 2010 17:02 Go to previous messageGo to next message
Some times you may want to automatically generate object diagrams without user intervention for testing purposes. Which is what I'm trying to do.
wafaa wrote on Fri, 04 June 2010 05:52
yes, I see.
Re: InstanceSpecification of a Modeled Class [message #538082 is a reply to message #538005] Fri, 04 June 2010 17:05 Go to previous messageGo to next message
Thank you Christian, it is working now. I was looking at the wrong method.
Hector
Christian W. Damus wrote on Fri, 04 June 2010 09:25
Hi, Hector,
requirement.
Christian
> Hello,
> right approach.
> Thank you.
> Hector
Re: InstanceSpecification of a Modeled Class [message #628482 is a reply to message #537829] Thu, 03 June 2010 17:46 Go to previous messageGo to next message
hi
Re: InstanceSpecification of a Modeled Class [message #628484 is a reply to message #628482] Thu, 03 June 2010 18:27 Go to previous messageGo to next message
Hi Wafaa,
Hector
Re: InstanceSpecification of a Modeled Class [message #628492 is a reply to message #628484] Fri, 04 June 2010 05:52 Go to previous messageGo to next message
yes, I see.
Sorry I did not see the code :d
Re: InstanceSpecification of a Modeled Class [message #628493 is a reply to message #537829] Fri, 04 June 2010 09:25 Go to previous messageGo to next message
Hi, Hector,
requirement.
Christian
> Hello,
> right approach.
> Thank you.
> Hector
Re: InstanceSpecification of a Modeled Class [message #628495 is a reply to message #628492] Fri, 04 June 2010 17:02 Go to previous messageGo to next message
> yes, I see.
Re: InstanceSpecification of a Modeled Class [message #628496 is a reply to message #538005] Fri, 04 June 2010 17:05 Go to previous message
Hector
> Hi, Hector,
> requirement.
> Cheers,
> Christian
> > Hello,
> > right approach.
> > Thank you.
> > Hector
Previous Topic:Re: how to attach ocl constraint to uml class
Next Topic:Re: Help! Not understanding state machine diagram to implementation
Current Time: Sun Jul 27 07:22:12 EDT 2025
Powered by FUDForum. Page generated in 0.05334 seconds
