Home » Archived » IMP » Error initializing parser for input
Error initializing parser for input [message #537680] Thu, 03 June 2010 07:22 Go to next message
I'm trying to use the last IMP build to create new Language for Eclipse 3.5.
When i try to test plugin for my JScript file flash_commands.js - i got Coloring, but nothing else (i create plugins for outline and etc - how said at documentation). And there is the next errors:
Error initializing parser for input flash_commands.js:
org.eclipse.imp.model.ModelFactory$ModelException: No such element:
	at org.eclipse.imp.model.ModelFactory.doOpen(ModelFactory.java:127)
	at org.eclipse.imp.model.ModelFactory.open(ModelFactory.java:122)
	at org.eclipse.imp.editor.UniversalEditor.initializeParseController(UniversalEditor.java:730)
	at org.eclipse.imp.editor.UniversalEditor.createPartControl(UniversalEditor.java:693)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
	at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1417)
	at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:942)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3885)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3506)
	at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
	at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
is this normal? If not - how to fix this?
Re: Error initializing parser for input [message #537697 is a reply to message #537680] Thu, 03 June 2010 08:03 Go to previous messageGo to next message
Problem is solved. I just try to open files without a Project. When i create project and open file from it - there not problems.
Re: Error initializing parser for input [message #537817 is a reply to message #537697] Thu, 03 June 2010 13:07 Go to previous messageGo to next message
IMP is supposed to be able to (and mostly does) handle opening source
files that don't belong to any workspace project (e.g., files that live
entirely outside the workspace).
I.e., this sounds like a bug. If you can send a bit more info, hopefully
we can diagnose and fix it.
If you can, please open a bug in bugzilla for this so we can track it.
Thanks!
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
Re: Error initializing parser for input [message #537959 is a reply to message #537817] Fri, 04 June 2010 06:26 Go to previous messageGo to next message
Robert M. Fuhrer wrote on Thu, 03 June 2010 13:07
Thanks!
-- Bob
Robert M. Fuhrer
Looks like all works fine, withing errors. I haven't outline and folding because of wrong parsing rules . But anyway - later i try to open different files without projects - and if bug will give any problems i will post it.
Re: Error initializing parser for input [message #577862 is a reply to message #537680] Thu, 03 June 2010 08:03 Go to previous messageGo to next message
Re: Error initializing parser for input [message #577909 is a reply to message #537697] Thu, 03 June 2010 13:07 Go to previous messageGo to next message
Thanks!
-- Bob
Robert M. Fuhrer
Re: Error initializing parser for input [message #577969 is a reply to message #537817] Fri, 04 June 2010 06:26 Go to previous message
> Thanks!
> Cheers,
> -- Bob
> Robert M. Fuhrer
Previous Topic:Problem with occurence marker
Next Topic:Unicode
Current Time: Wed Jul 23 08:48:50 EDT 2025
Powered by FUDForum. Page generated in 0.07442 seconds
