Home » Eclipse Projects » Rich Client Platform (RCP) » Retrieving Menu Contributions programmatically
Retrieving Menu Contributions programmatically [message #537950] Fri, 04 June 2010 05:57 Go to next message
Is there a possibility to determine the context menu of a given object? There must be one, because this is done in the Eclipse UI ...
The Use Case is: Menu Contributions are defined in plugins and the should exposed via a kind of web service to a web application ... so that valid context menus can be retrieved by using the Eclipse RCP techniques.
Where could I start searching?
Thank you
Heinrich
[Updated on: Fri, 04 June 2010 06:01] by Moderator
Re: Retrieving Menu Contributions programmatically [message #538013 is a reply to message #537950] Fri, 04 June 2010 08:44 Go to previous message
You cannot access a view's context menu, or their view menu, etc (at
least not really).
But you can take an arbitrary ContributionManager and populate it with
the org.eclipse.ui.menus extension point contributions.
See
org.eclipse.ui.menus.IMenuService.populateContributionManage r(ContributionManager,
String) and
org.eclipse.ui.menus.IMenuService.releaseContributions(Contr ibutionManager)
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:[e4] How to get ready ?
Next Topic:Disposing wizard page resources
Current Time: Wed Jul 23 10:46:00 EDT 2025
Powered by FUDForum. Page generated in 0.79586 seconds
