Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Is there a way to always show the scrollbar for a List?
Is there a way to always show the scrollbar for a List? [message #537264] Tue, 01 June 2010 13:29 Go to next message
I'm using org.eclipse.swt.widgets.List and I want to always show the
scrollbar (disabled if the list doesn't need to be scrolled, enabled if it
does). Is there a way to do this?
Re: Is there a way to always show the scrollbar for a List? [message #537334 is a reply to message #537264] Wed, 02 June 2010 01:30 Go to previous messageGo to next message
package org.eclipse.swt.snippets;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.List;
import org.eclipse.swt.widgets.ScrollBar;
import org.eclipse.swt.widgets.Shell;
public class Snippet
    static Display display;
    static Shell shell;
    public static void main(String[] args)
        display = new Display();
        shell = new Shell(display);
        shell.setSize(300, 300);
        shell.open();
        shell.setLayout(new GridLayout(5, true));
        List list = new List(shell, SWT.MULTI | SWT.V_SCROLL | SWT.H_SCROLL);
        GridData layoutData = new GridData(GridData.FILL_BOTH);
        list.setLayoutData(layoutData);
        list.setItems(new String[] { "1", "2", "3" });
        list.addSelectionListener(new SelectionListener()
            public void widgetSelected(SelectionEvent e)
                // TODO Auto-generated method stub
            public void widgetDefaultSelected(SelectionEvent e)
                System.out.println();
        shell.layout();
        ScrollBar hBar = list.getHorizontalBar();
        if (hBar != null) hBar.setVisible(true);
        ScrollBar vBar = list.getVerticalBar();
        if (vBar != null) vBar.setVisible(true);
        while (!shell.isDisposed())
            if (!display.readAndDispatch()) display.sleep();
        display.dispose();
pls modify the code further to sute your needs...
[Updated on: Wed, 02 June 2010 01:33] by Moderator
Re: Is there a way to always show the scrollbar for a List? [message #537881 is a reply to message #537334] Thu, 03 June 2010 23:13 Go to previous messageGo to next message
Thank you for your reply. I see that your example does work and that's what
I thought I'd need to do, however something is overriding the value that is
set via the scrollbar visible property. My list is declared within a
org.eclipse.jface.wizard.WizardPage (which is added to an
org.eclipse.jface.wizard.Wizard). Does anyone know how to always show a
list's scrollbars when the list is declared within a JFace WizardPage?
Re: Is there a way to always show the scrollbar for a List? [message #537885 is a reply to message #537881] Fri, 04 June 2010 00:55 Go to previous messageGo to next message
Notice that the layout is done defore and setting visible is done after...
shell.layout();
if u do it the other way the same thing will happen which is happening to u...
Re: Is there a way to always show the scrollbar for a List? [message #537938 is a reply to message #537885] Fri, 04 June 2010 04:55 Go to previous message
Thanks that fixed my issue.
Previous Topic:SWT_AWT compatibility
Next Topic:Wizard page's content does not show in a standalone JFace/SWT application
Current Time: Sat Jul 26 02:53:50 EDT 2025
Powered by FUDForum. Page generated in 0.47226 seconds
