Home » Modeling » GMF (Graphical Modeling Framework) » Design Label uses GMF icons instead of XXX.edit icons
Design Label uses GMF icons instead of XXX.edit icons [message #537873] Thu, 03 June 2010 20:06
I had an issue in my editor where certain elements were not displaying
the expected icons (i.e. from generated XXX.edit/icons), but were still
displaying correctly in the tool palette.
After much debugging, I found the problem is that even though I had
specified the Label to have Element Icon=true in the .gmfgraph, I had
set the Label as a Design Label in the .gmfmap.
As a result, the generated LabelEditPart#getParserElement() was
returning getModel() rather than resolveSemanticElement(), and
consequently I think the GMF editor was rendering the icon from the GMF
..edit plugin, and not the expected element from my XXX.edit plugin.
Changing the label to a normal Label Mapping resolved the issue.
Is this expected behaviour? Perhaps the Wiki should be updated to
specify that Design Labels will only use GMF icons, and not XXX.edit
icons. http://wiki.eclipse.org/GMF_Labels
Cheers
Jevon
Previous Topic:icons (gif) not shown in palette
Next Topic:Probelm with GenerateDiagramCode ant task
Current Time: Thu Jul 17 22:32:44 EDT 2025
Powered by FUDForum. Page generated in 0.04489 seconds
