Home » Eclipse Projects » Rich Client Platform (RCP) » Product Export (The Product export wizard wizard does not generate an executable)
Product Export [message #537786] Thu, 03 June 2010 12:00 Go to next message
I'm working on a eclipse RCP application, everything is working well and the platform is really awesome.
My single problem so far is the plug-in export as a standalone application : when i use the wizard to export the product it does not create the executable.
In the destination folder i have the 2 folders :
+ eclipse
-+ p2
-+plugins
-artifacts.xml
+ repository
-+plugins
-+artifacts.jar
-content.jar
I have already successfully exported an other project and have compared the 2 plugin.xml as well as the 2 product configurations and can't figure out the difference.
I have tried everything and have no ideas anymore, please help me T_T
Thanks by advance.
Pierre GAUTIER
Re: Product Export [message #537835 is a reply to message #537786] Thu, 03 June 2010 15:27 Go to previous messageGo to next message
In the .product file on the overview tab, there is a checkbox "The product
includes native launcher artifacts". Make sure this is checked.
-Andrew
GAUTIER Pierre wrote:
> Hello,
> executable.
> + eclipse
> -+ p2
> -+plugins
> -artifacts.xml
> + repository
> -+plugins
> -+artifacts.jar
> -content.jar
> out the difference.
> Thanks by advance.
> Pierre GAUTIER
Re: Product Export [message #537955 is a reply to message #537835] Fri, 04 June 2010 06:13 Go to previous messageGo to next message
It was checked, it would have been too easy.
Still looking for a solution I really cant figure what's wrong ....
P. GAUTIER
Re: Product Export [message #538199 is a reply to message #537955] Sun, 06 June 2010 06:19 Go to previous messageGo to next message
Don't know if it is related but I had problems with product export a while ago (some plugins didn't get exported, missing launchers, etc.).
Everything got back to normal after unchecking the "Generate a metadata repository" in the product export dialog and setting a brand new export directory.
I think / guess p2 is maintaining some kind of cache of what has already been exported and what hasn't. It only export elements based on this repository, but if you did any kind of file manipulations it won't work.
It might also work to try to a brand new directory without unchecking the option.
It worked for me, hope it will work for you.
Christophe
http://www.nextep-softwares.com
icon14.gif  Re: Product Export [message #538318 is a reply to message #538199] Mon, 07 June 2010 06:46 Go to previous messageGo to next message
Hey Christophe,
Your solution worked very well.
I will never thank you enough, I had this problem for days.
Thanks you very much !!!
P. GAUTIER
edit : anyway to set this problem as 'solved' ?
[Updated on: Mon, 07 June 2010 06:47] by Moderator
Re: Product Export [message #549175 is a reply to message #538318] Sun, 25 July 2010 17:32 Go to previous messageGo to next message
Hi Pierre,
Add plugin org.eclipse.rcp to your plugin dependencies.
Damien
[Updated on: Sun, 25 July 2010 17:33] by Moderator
Re: Product Export [message #553273 is a reply to message #537786] Mon, 16 August 2010 18:21 Go to previous messageGo to next message
Hi Pierre, Christophe,
I too have see the same behaviour when trying to export a very simple RCP app using PDE export in Eclipse 3.6. It seemed like the export progress dialog just vanished at ~80% and I was left with an incomplete export (exactly like you Pierre - no exe or ini file).
Unselecting "generate metadata repository" and picking a new destination directory resolved the issue, but I'd like to find out more about what's going on here - is there something sensible I can do to get some verbose output from the export? Has anyone else seen this behaviour or can shed some light on what may be happening?
Dan
[Updated on: Mon, 16 August 2010 18:22] by Moderator
icon7.gif  Re: Product Export [message #553414 is a reply to message #537786] Tue, 17 August 2010 09:29 Go to previous message
I discovered my issue was due to having a product definition ID that was the same as my application plugin id. When "Generate metadata repository" was selected on the export wizard the ID's clashed behind the scenes - however this was not obvious to the end-user other than having missing executables etc.
See: http://eclipsercp.org/2010/07/chapter-9-errata/
Dan
Previous Topic:pass data between wizard page
Next Topic:Get corresponding view in AbstractHandler.execute()
Current Time: Wed Jul 23 22:13:21 EDT 2025
Powered by FUDForum. Page generated in 0.06106 seconds
