Problem with occurence marker [message #536947] |
Mon, 31 May 2010 11:48  |
I created an occurence marker as described in the PIMP Your Eclipse tutorial from 2009, but it does not seem to work correctly:
The getOccurencesOf method does not get invoked when the selection changes inside the editor, only when the editor opens or I change editors, and even the only once.
This way its impossible to provide occurrence marking, as the universal editor does not know about the possible occurences.
I don't know whether this is a bug, or I am missing something, can you guide me? I'm using the actual release from the update site.
Thank you for your help,
Zoltán Ujhelyi
Re: Problem with occurence marker [message #537834 is a reply to message #536947] |
Thu, 03 June 2010 15:25   |
> Zoltán Ujhelyi
This definitely looks like a bug. Can you log a bug in bugzilla?
I'll take a look.
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
FUDForum. Page generated in 0.23835 seconds
