Home » Modeling » TMF (Xtext) » [TCS] Inferred property
[TCS] Inferred property [message #5378] Fri, 14 March 2008 06:04 Go to next message
I am trying to evaluate whether TCS currently allows to define an
expression syntax with dynamically typed variables, where the Injector
resolves the type.
Assuming I had this Metamodel:
class TypedElement
attribute type : String;
Class Variable extends Typed {
attribute name : String;
Class Expression extends Typed {
reference sequence container : Sequence;
Class Assignment {
reference var : Variable;
reference expression : Expression;
Can I somehow define a Syntax with TCS where
x = "Hello World"
lets the TCSInjector set property "type" of variable x to String, because
the type of "Hello World" would be String?
Or would I have to do this after Injecting as a semantical task
independent from the Syntax.
Re: [TCS] Inferred property [message #7331 is a reply to message #5378] Fri, 14 March 2008 06:39 Go to previous message
> Can I somehow define a Syntax with TCS where x = "Hello World"
> because the type of "Hello World" would be String?
What you want to do is a kind of semantic analysis. You have to do this
after injecting. Note that you can use ATL for this purpose.
Frédéric Jouault
Previous Topic:[TCS] NullPointerException with builder setup
Next Topic:[TCS] indexing values in list property
Current Time: Wed Jul 23 14:06:41 EDT 2025
Powered by FUDForum. Page generated in 0.04665 seconds
