Home » Eclipse Projects » EclipseLink » Map to a column that may not exist
Map to a column that may not exist [message #537682] Thu, 03 June 2010 07:33 Go to next message
Hi!
I have a number of tables with the same structure so I have a base class with all the annotation mappings. The thing is, some of these tables may later on be extended with a new column. Is it possible to add a column mapping in which the column is not guaranteed to be there or do I have to go in and make changes as the tables are updated?
Thanks!
/Matti
Re: Map to a column that may not exist [message #537732 is a reply to message #537682] Thu, 03 June 2010 09:48 Go to previous messageGo to next message
You have to make the changes when the tables are updated.
Re: Map to a column that may not exist [message #537734 is a reply to message #537732] Thu, 03 June 2010 09:56 Go to previous message
Ah. Oh, well. Thanks!
Previous Topic:NullPointerException on combining inheritance strategies (table per class + joined)
Next Topic:jpql query mystery
Current Time: Sat Sep 27 06:24:45 EDT 2025
Powered by FUDForum. Page generated in 0.04931 seconds
