Home » Archived » M2M (model-to-model transformation) » Using M2M in C#
Using M2M in C# [message #537717] Thu, 03 June 2010 09:10 Go to next message
I've created neccessary models, model rules and transformed successfully in an ATL project. Could you introduce me some ways to call those transformations at runtime in C#. I'm using VS 2008 to develop my application. Thanks in advance
Re: Using M2M in C# [message #537724 is a reply to message #537717] Thu, 03 June 2010 09:18 Go to previous messageGo to next message
If you are able to launch a java program from C#, you may execute an
Eclipse application.
ATL runs in Eclipse/Java world, so you have to wrap your (ATL)
tranformation environnement in order to execute it from a C# program.
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: Using M2M in C# [message #537740 is a reply to message #537724] Thu, 03 June 2010 10:09 Go to previous messageGo to next message
Hi Vincent MAHE,
Thanks for your reply but I still have some questions to ask.
Even if it's possible to run a Java application from C#, could you show me how to deploy an ATL project to ... a jar file for instance ? I'm new to ATL. So, I really need your help.
Re: Using M2M in C# [message #537748 is a reply to message #537740] Thu, 03 June 2010 10:27 Go to previous messageGo to next message
Le 03/06/2010 16:09, Ton Tu a écrit :
> Hi Vincent MAHE,
You may have a look on ATL 3 new API in order to know how to wrap an ATL
transformation: http://wiki.eclipse.org/ATL/Developer_Guide#Core
I never did a jar packaging of Eclipse application so you will have to
explore this question by yourself :-(
Cordialement
Vincent MAHÉ
Re: Using M2M in C# [message #537767 is a reply to message #537748] Thu, 03 June 2010 11:19 Go to previous messageGo to next message
Anyway, thank a lot for your enthusiasm Smile
Re: Using M2M in C# [message #537913 is a reply to message #537767] Fri, 04 June 2010 03:26 Go to previous messageGo to next message
Le 03/06/2010 17:19, Ton Tu a écrit :
> Anyway, thank a lot for your enthusiasm :)
You may be interested by this AmmA.Net :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284848
Cordialement
Vincent MAHÉ
Re: Using M2M in C# [message #538168 is a reply to message #537913] Sat, 05 June 2010 20:57 Go to previous messageGo to next message
I still cannot use those namespaces to run ATL rules successfully. Could you please give me a snippet of code to run those namespaces ? I will appreciate you a lot ...
I'm getting tired of not being able to run ATL rules which are neccessary for my university thesis ... I've come through many articles instructing how to wrap ATL but none of them is compilable ... I wonder if there's any problem with Eclipse configuration ? Would you mind helping me ?
[Updated on: Sat, 05 June 2010 20:59] by Moderator
Re: Using M2M in C# [message #538269 is a reply to message #538168] Mon, 07 June 2010 03:50 Go to previous messageGo to next message
> appreciate you a lot ... I'm getting tired of not being able to run ATL
As an example of ATL Java launcher :
> import java.net.URL;
> import java.util.Collections;
> import java.util.HashMap;
> import java.util.Map;
> import org.eclipse.core.runtime.NullProgressMonitor;
> import org.eclipse.core.runtime.Platform;
> import org.eclipse.m2m.atl.core.ATLCoreException;
> import org.eclipse.m2m.atl.core.IExtractor;
> import org.eclipse.m2m.atl.core.IInjector;
> import org.eclipse.m2m.atl.core.IModel;
> import org.eclipse.m2m.atl.core.IReferenceModel;
> import org.eclipse.m2m.atl.core.ModelFactory;
> import org.eclipse.m2m.atl.core.launch.ILauncher;
> import org.eclipse.m2m.atl.core.service.CoreService;
> public class ATLInterface
> * The injector used to load models to XMI files
> private static IInjector injector;
> * The extractor used to save models in XMI files
> private static IExtractor extractor;
> * The URL of the compiled transformation
> private static URL transfoURL;
> * This initializes the ATL interface at first load
> static {
> transfoURL = Platform.getBundle("org.xx.zz.my.plugin")
> .getEntry("transformation/myTransfo.asm");
> try {
> injector = CoreService.getInjector(EMF);
> extractor = CoreService.getExtractor(EMF);
> } catch (ATLCoreException e) {
> e.printStackTrace();
> * Call the transformation onto the <code>inFilePath</code> and store the result in the
> * <code>outFilePath</code> file.
> * @param inFilePath
> * The path to the input model
> * @param outFilePath
> * The path to the output model
> public static void transform(String inFilePath, String outFilePath)
> try
> ModelFactory factory = CoreService.getModelFactory(EMF);
> ILauncher launcher = CoreService.getLauncher(EMF-specific VM);
> launcher.initialize(Collections.<String, Object> emptyMap()) ;
> IReferenceModel inMM = factory.newReferenceModel();
> injector.inject(inMM, "**inMetamodelUri**");
> IReferenceModel outMM = factory.newReferenceModel();
> injector.inject(outMM, "**outMetamodelUri**");
> // get/create models
> IModel inModel = factory.newModel(inMM);
> injector.inject(inModel, inFilePath);
> launcher.addInModel(inModel, "IN", "IN_MM"); // use ATL transfo codes
> IModel outModel = factory.newModel(outMM);
> launcher.addOutModel(outModel, "OUT", "OUT_MM");
> // add the continue after errors options
> Map<String, Object> options = new HashMap<String, Object>();
> options.put("continueAfterError", "true");
> options.put("printExecutionTime", "true");
> // launch the transformation
> launcher.launch(ILauncher.RUN_MODE, new NullProgressMonitor(),
> options, transfoURL.openStream());
> extractor.extract(outModel, outFilePath);
> catch (Exception e)
Cordialement
Vincent MAHÉ
Re: Using M2M in C# [message #538676 is a reply to message #538269] Tue, 08 June 2010 08:01 Go to previous message
I try to follow your instructions. But the method "Platform.getBundle ()" always returns the exception java.lang.NullPointerException.
I do not know yet how to fix it. Can you help me?
http://i149.photobucket.com/albums/s69/alainnguyen00/Untitled.png
[Updated on: Tue, 08 June 2010 08:02] by Moderator
Previous Topic:[QVTo] Mapping 1 to many objects results in output object appearing as siblings
Next Topic:[ATL] ant tasks problem: 'Unable to load launcher EMF-specific VM'
Current Time: Fri Sep 12 22:04:49 EDT 2025
Powered by FUDForum. Page generated in 0.32624 seconds
