Home » Archived » BIRT » Problem to set data/element into cells created by adding column dynamically in two-dimensional table
Problem to set data/element into cells created by adding column dynamically in two-dimensional table [message #537707] Thu, 03 June 2010 08:38 Go to next message
I've created a two-dimensional table in birt.
Now, using BIRT report engine api, through my java code, I am adding one column in my table (say country column) at the end of the table, and hence want to insert data into these newly created cells (these cells created because of adding this column column dynamically)
Suppose, I want to add data/element in these newly created cells, I am unable to do so, its not working for two-dimensional table. If I try to add column and then add labels in the cells for simple table, it works.
Below is my code snippet and format of my table I've created.
public class MyDynamicTable extends ReportEventAdapter
    public void beforeFactory(IReportDesign report, IReportContext reportContext)
    	try{
		    ElementFactory elementFactory = reportContext.getReportRunnable().getDesignHandle().getElementFactory();
		    TableHandle dynamicTable = (TableHandle) reportContext.getDesignHandle().findElement("topCntry"); //table name is "topCntry"
	    	dynamicTable.insertColumn(5, 1);
	    	RowHandle myNewCntry = (RowHandle) dynamicTable.getDetail().get(0);
	    	RowHandle myNewPercent = (RowHandle) dynamicTable.getDetail().get(1);
	    	RowHandle myNewHits = (RowHandle) dynamicTable.getDetail().get(2);
	    	CellHandle firstCell = (CellHandle) myNewCntry.getCells().get(5);
	    	CellHandle secondCell = (CellHandle) myNewPercent.getCells().get(5);
	    	CellHandle thirdCell = (CellHandle) myNewHits.getCells().get(5);
	    	//create new labels
	    	LabelHandle label1 = elementFactory.newLabel("Cell1");
	    	label1.setText("D Cell");
	    	LabelHandle label2 = elementFactory.newLabel("Cell2");
	    	label2.setText("E Cell");
	    	LabelHandle label3 = elementFactory.newLabel("Cell3");
	    	label3.setText("F Cell");
	    	firstCell.getContent().add(label1);
	    	secondCell.getContent().add(label2);
	    	thirdCell.getContent().add(label3);
		} catch(Exception e){
			e.printStackTrace();
Two-dimensional Table format -
My table name is "topCntry"
 Sr No.  	User id  	Parameter  	Country-1  Country-2
  	                	 Country	  USA       UK
 1             abcde            Percentage 	  45% 	   59.6%
                                 Hits 	          45       59
Help is highly appreciated.
Thank you,
prodigy201
Re: Problem to set data/element into cells created by adding column dynamically in two-dimensional t [message #537779 is a reply to message #537707] Thu, 03 June 2010 11:25 Go to previous messageGo to next message
Not sure this is what you are asking, but if you want to add a data item
you need to make sure a column binding exist for it on the table first:
PropertyHandle computedSet = table.getColumnBindings( );
ComputedColumn cs1;
cs1 = StructureFactory.createComputedColumn();
cs1.setName("CustomerName");
cs1.setExpression("dataSetRow[\"CUSTOMERNAME\"]");
computedSet.addItem(cs1);
RowHandle tabledetail = (RowHandle) table.getDetail( ).get( 0 );
cell = (CellHandle) tabledetail.getCells( ).get( 0 );
DataItemHandle data = designFactory.newDataItem( "data1" );
data.setResultSetColumn("CustomerName");
cell.getContent( ).add( data );
Jason
On 6/3/2010 8:38 AM, prodigy201 wrote:
> reportContext)
> try{
> reportContext.getReportRunnable().getDesignHandle().getEleme ntFactory();
> "topCntry"
> //create new labels
> Country USA UK
> Hits 45 59
> Thank you,
> prodigy201
Re: Problem to set data/element into cells created by adding column dynamically in two-dimensional t [message #537894 is a reply to message #537707] Fri, 04 June 2010 02:34 Go to previous messageGo to next message
Hi Jason,
Well, you've taken DATA and I've taken LABEL instead of DATA in cell in my new column. So it doesn't actually makes a difference what you want to insert in cell.
My worry is how to add DATA/LABEL/ANY ELEMENT in the every cell of the same column where row is same. I mean to say, as I've shown table format in my thread previously, (displaying two-dimensional table format again at the end of this reply) where you will find I want to fill 3 cells for new dynamically added column say country-3, in these 3 cells I want to add country name, percentage and hits for this country-3. That is, for same "Sr.No" say 1, for same "User ID" say "abcde", I want to fill data for newly added column for country-3, as I've initially done for country-1 to country-2 that was done by designing rptdesign file using table. And I am working for adding new column dynamically on this already created table.
I am just able to insert only for country name that is first cell, but am UNsuccessful to add for percentage and hits for the same, those fall in cell2 and cell3.
I hope you got my query. And I am sure you will be helpful for this, as I'm referring your book only. "Integrating and Extending BIRT" Smile
Table format - ("Parameter" column's data is static. i.e "Country", "Percentage", "Hits" are static labels)
  	                	 Country	  USA       UK
                                 Hits 	          45       59
P.S. - I request you to go through my code again that I've posted earlier in my thread, so you'll surely come to know what I am actually trying to do.
Thank you,
prodigy201
ComputedColumn cs1;
Jason
> reportContext)
> try{
> "topCntry"
> //create new labels
> Country USA UK
> Hits 45 59
> Thank you,
> prodigy201
[Updated on: Fri, 04 June 2010 02:47] by Moderator
Re: Problem to set data/element into cells created by adding column dynamically in two-dimensional t [message #538030 is a reply to message #537894] Fri, 04 June 2010 10:21 Go to previous messageGo to next message
Can you post the report design?
this code implies that you have 3 detail rows. Is this correct or do
you have one detail, a header, and a footer?
Jason
Re: Problem to set data/element into cells created by adding column dynamically in two-dimensional t [message #538588 is a reply to message #538030] Tue, 08 June 2010 03:09 Go to previous messageGo to next message
Hi Jason,
Please go through the XML (rptdesign) for my report given below.
And yeah, you are right, my report has 3 sub-rows in 1 main row. You will find in my reprt design, I've used classicmodels for DB source and DATA SET just for now to bind it to my table. (Its just for binding Dataset to table, It has nothing to do with my report though, as my actual dataset is surely going to be different).
Moreover, you'll observe the actual format of report and will get idea of data I want to represent. Instead of DATA ELEMENT, I've taken LABELS (just for now) in every cell. (Every cell will be filled with DATA ELEMENT only later). The third column "Parameters" will get repeated everytime with its "static labels" - "Country", "No. of Applications", "Accepted Applications".
I want to add 3 columns - Country-3 to Country-5 dynamically in this table, and hence the data in every cell dynamically. But, as per my JAVA code(given below), its only adding DATA/LABEL for "Country" only and NOT FOR "No. of Applications", "Accepted Applications". Now, I hope you understood what I want to do.
RowHandle myNewApplis = (RowHandle) dynamicTable.getDetail().get(1);
RowHandle myNewSelectdApplis = (RowHandle) dynamicTable.getDetail().get(2);
Following is XML for rptdesign. -
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20" id="1">
    <property name="createdBy">Eclipse BIRT Designer Version 2.5.1.v20090903 Build &lt;2.5.1.v20090917-1447></property>
    <property name="units">in</property>
    <property name="iconFile">/templates/blank_report.gif</property>
    <property name="bidiLayoutOrientation">ltr</property>
    <data-sources>
        <oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="408">
            <text-property name="displayName"></text-property>
            <property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver</property>
            <property name="odaURL">jdbc:classicmodels:sampledb</property>
            <property name="odaUser">ClassicModels</property>
        </oda-data-source>
    </data-sources>
    <data-sets>
        <oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="Data Set" id="409">
            <list-property name="columnHints">
                <structure>
                    <property name="columnName">CUSTOMERNUMBER</property>
                    <text-property name="displayName">CUSTOMERNUMBER</text-property>
                </structure>
            </list-property>
            <structure name="cachedMetaData">
                <list-property name="resultSet">
                    <structure>
                        <property name="position">1</property>
                        <property name="name">CUSTOMERNUMBER</property>
                        <property name="dataType">integer</property>
                    </structure>
                </list-property>
            </structure>
            <property name="dataSource">Data Source</property>
                <structure>
                    <property name="nativeName">CUSTOMERNUMBER</property>
                    <property name="nativeDataType">4</property>
                </structure>
            </list-property>
            <xml-property name="queryText"><![CDATA[select CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER
from CLASSICMODELS.CUSTOMERS]]></xml-property>
            <xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
  <Version>1.0</Version>
  <design:ResultSets derivedMetaData="true">
    <design:resultSetDefinitions>
      <design:resultSetColumns>
        <design:resultColumnDefinitions>
          <design:attributes>
            <design:name>CUSTOMERNUMBER</design:name>
            <design:position>1</design:position>
            <design:nativeDataTypeCode>4</design:nativeDataTypeCode>
            <design:precision>10</design:precision>
            <design:scale>0</design:scale>
            <design:nullability>Nullable</design:nullability>
            <design:uiHints>
              <design:displayName>CUSTOMERNUMBER</design:displayName>
            </design:uiHints>
          </design:attributes>
          <design:usageHints>
            <design:label>CUSTOMERNUMBER</design:label>
            <design:formattingHints>
              <design:displaySize>11</design:displaySize>
            </design:formattingHints>
          </design:usageHints>
        </design:resultColumnDefinitions>
      </design:resultSetColumns>
    </design:resultSetDefinitions>
  </design:ResultSets>
</model:DesignValues>
]]></xml-property>
        </oda-data-set>
    </data-sets>
    <styles>
        <style name="rowSetting" id="192">
            <property name="borderBottomStyle">solid</property>
            <property name="borderBottomWidth">thin</property>
            <property name="borderLeftStyle">solid</property>
            <property name="borderLeftWidth">thin</property>
            <property name="borderRightStyle">solid</property>
            <property name="borderRightWidth">thin</property>
            <property name="borderTopStyle">solid</property>
            <property name="borderTopWidth">thin</property>
            <property name="textAlign">center</property>
            <property name="verticalAlign">middle</property>
        </style>
        <style name="colSetting" id="193">
        </style>
        <style name="gridRowStyle" id="203">
            <structure name="numberFormat">
                <property name="category">General Number</property>
                <property name="pattern">General Number</property>
            </structure>
        </style>
    </styles>
    <page-setup>
        <simple-master-page name="Simple MasterPage" id="2">
            <page-footer>
                <text id="3">
                    <property name="contentType">html</property>
                </text>
            </page-footer>
        </simple-master-page>
    </page-setup>
    <body>
        <table id="270">
            <property name="borderBottomColor">#000000</property>
            <property name="borderLeftColor">#000000</property>
            <property name="borderRightColor">#000000</property>
            <property name="borderTopColor">#000000</property>
            <property name="marginTop">30pt</property>
            <property name="marginLeft">15pt</property>
            <property name="marginBottom">30pt</property>
            <property name="width">7.647058823529412in</property>
            <property name="dataSet">Data Set</property>
            <list-property name="boundDataColumns">
                <structure>
                    <expression name="expression">dataSetRow["CUSTOMERNUMBER"]</expression>
                </structure>
            </list-property>
            <column id="326">
                <property name="width">0.5529411764705883in</property>
                <property name="style">colSetting</property>
            </column>
            <column id="327">
                <property name="width">0.9176470588235294in</property>
            </column>
            <column id="328">
            </column>
            <column id="329">
                <property name="width">0.8117647058823529in</property>
            </column>
            <column id="330">
            </column>
            <header>
                <row id="271">
                    <cell id="272">
                        <property name="fontWeight">bold</property>
                        <label id="336">
                            <property name="fontSize">9pt</property>
                            <text-property name="text">Sr.No</text-property>
                        </label>
                    </cell>
                    <cell id="273">
                        <label id="337">
                            <text-property name="text">User ID</text-property>
                        </label>
                    </cell>
                    <cell id="274">
                        <label id="338">
                            <text-property name="text">Parameter</text-property>
                        </label>
                    </cell>
                    <cell id="275">
                        <label id="339">
                            <text-property name="text">Country-1</text-property>
                        </label>
                    </cell>
                    <cell id="276">
                        <label id="340">
                            <text-property name="text">Country-2</text-property>
                        </label>
                    </cell>
                </row>
            </header>
            <detail>
                <row id="282">
                    <property name="height">0.2235294117647059in</property>
                    <property name="style">rowSetting</property>
                    <cell id="283">
                        <property name="colSpan">1</property>
                        <property name="rowSpan">3</property>
                        <property name="scope">rowgroup</property>
                        <property name="showIfBlank">false</property>
                        <label id="407">
                            <text-property name="text">1</text-property>
                        </label>
                    </cell>
                    <cell id="284">
                        <label id="405">
                            <text-property name="text">abcde</text-property>
                        </label>
                    </cell>
                    <cell id="285">
                        <label id="351">
                            <text-property name="text">Country</text-property>
                        </label>
                    </cell>
                    <cell id="286">
                        <label id="410">
                            <text-property name="text">UK</text-property>
                        </label>
                    </cell>
                    <cell id="287">
                        <label id="411">
                            <property name="fontSize">medium</property>
                            <text-property name="text">USA</text-property>
                        </label>
                    </cell>
                </row>
                <row id="293">
                    <property name="height">0.24705882352941178in</property>
                    <cell id="296">
                        <label id="352">
                            <text-property name="text">No. of Applications</text-property>
                        </label>
                    </cell>
                    <cell id="297">
                        <label id="412">
                            <text-property name="text">112</text-property>
                        </label>
                    </cell>
                    <cell id="298">
                        <label id="413">
                            <text-property name="text">75</text-property>
                        </label>
                    </cell>
                </row>
                <row id="304">
                    <cell id="307">
                        <label id="353">
                            <text-property name="text">Accepted Applications</text-property>
                        </label>
                    </cell>
                    <cell id="308">
                        <label id="414">
                            <text-property name="text">52</text-property>
                        </label>
                    </cell>
                    <cell id="309">
                        <label id="415">
                            <text-property name="text">29</text-property>
                        </label>
                    </cell>
                </row>
            </detail>
        </table>
    </body>
</report>
Thank you,
prodigy201
[Updated on: Tue, 08 June 2010 06:00] by Moderator
Re: Problem to set data/element into cells created by adding column dynamically in two-dimensional t [message #538730 is a reply to message #538588] Tue, 08 June 2010 09:50 Go to previous messageGo to next message
The whole report did not come through. Could you email it to me at
jasonweathersby at windstream dot net?
BTW once you get the handle to the proper row:
This should be returning a specific column. Ie
//column 1
CellHandle firstCell = (CellHandle) myNewCntry.getCells().get(0);
//column 2
CellHandle firstCell = (CellHandle) myNewCntry.getCells().get(1);
Jason
On 6/8/2010 3:09 AM, prodigy201 wrote:
> Hi Jason,
> id="1">
> Build <2.5.1.v20090917-1447></property>
> <data-sources>
> <property
> name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </structure>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </simple-master-page><?xml version="1.0" encoding="UTF-8"?>
> id="1">
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </structure>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="270">
> <structure>
> <expression name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
> </structure>
> </list-property>
> <column id="326">
> </column>
> <column id="327">
> </column>
> <column id="328">
> </column>
> <column id="329">
> </column>
> <column id="330">
> </column>
> <header>
> <row id="271">
> <cell id="272">
> <label id="336">
> </label>
> </cell>
> <cell id="273">
> <label id="337">
> </label>
> </cell>
> <cell id="274">
> <label id="338">
> </label>
> </cell>
> <cell id="275">
> <label id="339">
> </label>
> </cell>
> <cell id="276">
> <label id="340">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="282">
> <cell id="283">
> <label id="407">
> </label>
> </cell>
> <cell id="284">
> <label id="405">
> </label>
> </cell>
> <cell id="285">
> <label id="351">
> </label>
> </cell>
> <cell id="286">
> <label id="410">
> </label>
> </cell>
> <cell id="287">
> <label id="411">
> </label>
> </cell>
> </row>
> <row id="293">
> <cell id="296">
> <label id="352">
> </label>
> </cell>
> <cell id="297"><?xml version="1.0" encoding="UTF-8"?>
> id="1">
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </structure>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="270">
> <structure>
> </structure>
> </list-property>
> <column id="326">
> </column>
> <column id="327">
> </column>
> <column id="328">
> </column>
> <column id="329">
> </column>
> <column id="330">
> </column>
> <header>
> <row id="271">
> <cell id="272">
> <label id="336">
> </label>
> </cell>
> <cell id="273">
> <label id="337">
> </label>
> </cell>
> <cell id="274">
> <label id="338">
> </label>
> </cell>
> <cell id="275">
> <label id="339">
> </label>
> </cell>
> <cell id="276">
> <label id="340">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="282">
> <cell id="283">
> <label id="407">
> </label>
> </cell>
> <cell id="284">
> <label id="405">
> </label>
> </cell>
> <cell id="285">
> <label id="351">
> </label>
> </cell>
> <cell id="286">
> <label id="410">
> </label>
> </cell>
> <cell id="287">
> <label id="411">
> </label>
> </cell>
> </row>
> <row id="293">
> <cell id="296">
> <label id="352"><?xml version="1.0" encoding="UTF-8"?>
> id="1">
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </structure>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="270">
> <structure>
> </structure>
> </list-property>
> <column id="326">
> </column>
> <column id="327">
> </column>
> <column id="328">
> </column>
> <column id="329">
> </column>
> <column id="330">
> </column>
> <header>
> <row id="271">
> <cell id="272">
> <label id="336">
> </label>
> </cell>
> <cell id="273">
> <label id="337">
> </label>
> </cell>
> <cell id="274">
> <label id="338">
> </label>
> </cell>
> <cell id="275">
> <label id="339">
> </label>
> </cell>
> <cell id="276">
> <label id="340">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="282">
> <cell id="283">
> <label id="407">
> </label>
> </cell>
> <cell id="284">
> <label id="405">
> </label>
> </cell>
> <cell id="285">
> <label id="351">
> </label>
> </cell>
> <cell id="286">
> <label id="410">
> </label>
> </cell>
> <cell id="287">
> <label id="411">
> </label>
> </cell>
> </row>
> <row id="293">
> <cell id="296">
> <label id="352">
> </label>
> </cell>
> <cell id="297">
> <label id="412">
> </label>
> </cell>
> <cell id="298">
> <label id="413">
> </label>
> </cell>
> </row>
> <row id="304">
> <cell id="307">
> <label id="353">
> </label>
> </cell>
> <cell id="308">
> <label id="414">
> </label>
> </cell>
> <cell id="309">
> <label id="415">
> </label>
> </cell>
> </row>
> </detail>
> </table>
> </body>
> </report>
> </label>
> </cell>
> <cell id="297">
> <label id="412">
> </label>
> </cell>
> <cell id="298">
> <label id="413">
> </label>
> </cell>
> </row>
> <row id="304">
> <cell id="307">
> <label id="353">
> <property name="fontWeight">bold</property&gt
Re: Problem to set data/element into cells created by adding column dynamically in two-dimensional t [message #539410 is a reply to message #538588] Thu, 10 June 2010 11:47 Go to previous message
I sent you an email with example code. You merged the rows for columns
1 and 2 for all three detail rows. So row one will have two more cells
than row 2 and 3.
Jason
> Hi Jason,
> id="1">
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </structure>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> id="1">
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </structure>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="270">
> <structure>
> </structure>
> </list-property>
> <column id="326">
> </column>
> <column id="327">
> </column>
> <column id="328">
> </column>
> <column id="329">
> </column>
> <column id="330">
> </column>
> <header>
> <row id="271">
> <cell id="272">
> <label id="336">
> </label>
> </cell>
> <cell id="273">
> <label id="337">
> </label>
> </cell>
> <cell id="274">
> <label id="338">
> </label>
> </cell>
> <cell id="275">
> <label id="339">
> </label>
> </cell>
> <cell id="276">
> <label id="340">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="282">
> <cell id="283">
> <label id="407">
> </label>
> </cell>
> <cell id="284">
> <label id="405">
> </label>
> </cell>
> <cell id="285">
> <label id="351">
> </label>
> </cell>
> <cell id="286">
> <label id="410">
> </label>
> </cell>
> <cell id="287">
> <label id="411">
> </label>
> </cell>
> </row>
> <row id="293">
> <cell id="296">
> <label id="352">
> </label>
> </cell>
> id="1">
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </structure>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="270">
> <structure>
> </structure>
> </list-property>
> <column id="326">
> </column>
> <column id="327">
> </column>
> <column id="328">
> </column>
> <column id="329">
> </column>
> <column id="330">
> </column>
> <header>
> <row id="271">
> <cell id="272">
> <label id="336">
> </label>
> </cell>
> <cell id="273">
> <label id="337">
> </label>
> </cell>
> <cell id="274">
> <label id="338">
> </label>
> </cell>
> <cell id="275">
> <label id="339">
> </label>
> </cell>
> <cell id="276">
> <label id="340">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="282">
> <cell id="283">
> <label id="407">
> </label>
> </cell>
> <cell id="284">
> <label id="405">
> </label>
> </cell>
> <cell id="285">
> <label id="351">
> </label>
> </cell>
> <cell id="286">
> <label id="410">
> </label>
> </cell>
> <cell id="287">
> <label id="411">
> </label>
> </cell>
> </row>
> <row id="293">
> <cell id="296">
> id="1">
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </structure>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="270">
> <structure>
> </structure>
> </list-property>
> <column id="326">
> </column>
> <column id="327">
> </column>
> <column id="328">
> </column>
> <column id="329">
> </column>
> <column id="330">
> </column>
> <header>
> <row id="271">
> <cell id="272">
> <label id="336">
> </label>
> </cell>
> <cell id="273">
> <label id="337">
> </label>
> </cell>
> <cell id="274">
> <label id="338">
> </label>
> </cell>
> <cell id="275">
> <label id="339">
> </label>
> </cell>
> <cell id="276">
> <label id="340">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="282">
> <cell id="283">
> <label id="407">
> </label>
> </cell>
> <cell id="284">
> <label id="405">
> </label>
> </cell>
> <cell id="285">
> <label id="351">
> </label>
> </cell>
> <cell id="286">
> <label id="410">
> </label>
> </cell>
> <cell id="287">
> <label id="411">
> </label>
> </cell>
> </row>
> <row id="293">
> <cell id="296">
> <label id="352">
> </label>
> </cell>
> <cell id="297">
> <label id="412">
> </label>
> </cell>
> <cell id="298">
> <label id="413">
> </label>
> </cell>
> </row>
> <row id="304">
> <cell id="307">
> <label id="353">
> </label>
> </cell>
> <cell id="308">
> <label id="414">
> </label>
> </cell>
> <cell id="309">
> <label id="415">
> </label>
> </cell>
> </row>
> </detail>
> </table>
> </body>
> </report>
> </label>
> </cell>
> <cell id="297">
> <label id="412">
> </label>
> </cell>
> <cell id="298">
> <label id="413">
> </label>
> </cell>
> </row>
> <row id="304">
> <cell id="307">
> <label id="353">
Previous Topic:Populating a table column-by-column
Next Topic:Variables in library
Current Time: Sat Jul 19 00:15:39 EDT 2025
Powered by FUDForum. Page generated in 0.04986 seconds
