Error initializing parser for input [message #537680] |
Thu, 03 June 2010 07:22  |
I'm trying to use the last IMP build to create new Language for Eclipse 3.5.
When i try to test plugin for my JScript file flash_commands.js - i got Coloring, but nothing else (i create plugins for outline and etc - how said at documentation). And there is the next errors:
Error initializing parser for input flash_commands.js:
org.eclipse.imp.model.ModelFactory$ModelException: No such element:
at org.eclipse.imp.model.ModelFactory.doOpen(ModelFactory.java:127)
at org.eclipse.imp.model.ModelFactory.open(ModelFactory.java:122)
at org.eclipse.imp.editor.UniversalEditor.initializeParseController(UniversalEditor.java:730)
at org.eclipse.imp.editor.UniversalEditor.createPartControl(UniversalEditor.java:693)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1417)
at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3506)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
is this normal? If not - how to fix this?
Re: Error initializing parser for input [message #577969 is a reply to message #537817] |
Fri, 04 June 2010 06:26  |
Robert M. Fuhrer wrote on Thu, 03 June 2010 13:07
> On 6/3/10 8:03 AM, Magisterion wrote:
> > Problem is solved. I just try to open files without a Project. When i
> > create project and open file from it - there not problems.
> IMP is supposed to be able to (and mostly does) handle opening source
> files that don't belong to any workspace project (e.g., files that live
> entirely outside the workspace).
> I.e., this sounds like a bug. If you can send a bit more info, hopefully
> we can diagnose and fix it.
> If you can, please open a bug in bugzilla for this so we can track it.
> Thanks!
> Cheers,
> -- Bob
> Robert M. Fuhrer
> Research Staff Member
> Programming Technologies Dept.
> IBM T.J. Watson Research Center
> IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
> X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
Looks like all works fine, withing errors. I haven't outline and folding because of wrong parsing rules . But anyway - later i try to open different files without projects - and if bug will give any problems i will post it.
FUDForum. Page generated in 0.06085 seconds
