Home » Eclipse Projects » EclipseLink » XML Composite Object Mapping problem
XML Composite Object Mapping problem [message #537550] Wed, 02 June 2010 16:43 Go to next message
I'm new to Eclipselink and I'm having trouble getting an XML mapping working,
I have the following Java classes:
public class Response {
List<ResourceStatus> rs;
List<ResourceLocation> rl;
public class ResourceStatus {
private String id;
private String status;
public class ResourceLocation {
private String id;
private Point posn;
My XML doc is:
<remc:Response>
<remc:ResourceStatusLocations>
<remc:ID>AAA</remc:ID>
<remc:Status>0</remc:Status>
<remc:Location>
<common:Coordinate>
<common:X>5.0</common:X>
<common:y>5.0</common:y>
</common:Coordinate>
</remc:Location>
</remc:ResourceStatusLocations>
<remc:ID>BBB</remc:ID>
<remc:Status>2</remc:Status>
<remc:Location>
<common:Coordinate>
<common:X>7.0</common:X>
<common:y>7.0</common:y>
</remc:Coordinate>
</remc:Location>
</remc:Response>
and the equivalent objects should be
Response
rl ["AAA", (5.0, 5.0)], ["BBB", (7.0, 7.0)]
rs ["AAA", "0"], ["BBB", "2"]
In my workbench (EclipseLink Workbench v2.0.2), I have:
Descriptor Response --> context = schema::nnn//element::remc:Response
- Attribute ResourceLocation mapped as a composite collection:
- xpath = remc:ResourceStatusLocation
- Reference descriptor = ResourceLocation
Desciptor ResourceLocation --> context = schema::nnn//complexType:remc:ResourceStatusLocation
- Attribute coordinate mapped as composite object using customiser code
final XMLCompositeObjectMapping mapping = new XMLCompositeObjectMapping();
mapping.setAttributeName("coordinate");
mapping.setXPath("remc:Location/common:Coordinate");
mapping.setReferenceClass(Point.class);
descriptor.addMapping(mapping);
However, when marshalling the object to XML, I've got the id and statuses mapped ok but the locations are missing:.
<remc:Response>
</remc:Response>
I have verified that the customiser code is being called and that the Point.class matches the Coordinate element.
Is this the right approach to take, am I missing something obvious here?
Den
Re: XML Composite Object Mapping problem [message #538844 is a reply to message #537550] Tue, 08 June 2010 14:36 Go to previous message
Hey Den,
The issue here is that you are attempting to map ResourceLocation in the context of a ResourceStatus, but these two objects aren't directly related in the object model. The way it is currently mapped would indicate to EclipseLink that ResourceStatus has a composite relationship to ResourceLocation, which is not the case. You can make use of our extended API to get this working, though. Here's one way to do it:
Use an object to hold on to the ResourceStatus/ResourceLocation pairs, like this:
public class ResourceStatusLocations {
  public ResourceStatus rs;
  public ResourceLocation rl;
Setup a mapping for a list of these ResourceStatusLocations on the Response descriptor like so:
    XMLCompositeCollectionMapping rslmapping = new XMLCompositeCollectionMapping();
    rslmapping.setXPath("remc:ResourceStatusLocations");
    rslmapping.setReferenceClass(ResourceStatusLocations.class);
    rslmapping.setAttributeAccessor(new RSLAttributeAccessor());
    rslmapping.setContainerPolicy(new ListContainerPolicy(ArrayList.class));
This list doesn't really exist, i.e. there is no List<ResourseStatusLocations> attribute on Response, and that's okay.
Do not map List<ResourceStatus> and List<ResourceLocation> on the Response descriptor.
The mappings for the new ResourceStatusLocations would look like:
    // mapping for ResourceStatus
    XMLCompositeObjectMapping rsmapping = new XMLCompositeObjectMapping();
    rsmapping.setAttributeName("rs");
    rsmapping.setXPath(".");
    rsmapping.setReferenceClass(ResourceStatus.class);
    // mapping for ResourceLocation
    XMLCompositeObjectMapping rlmapping = new XMLCompositeObjectMapping();
    rlmapping.setAttributeName("rl");
    rlmapping.setXPath("remc:Location");
    rlmapping.setReferenceClass(ResourceLocation.class);
We will use a custom accessor that populates the ResourceStatusLocations objects based on List<ResourceStatus> and List<ResourceLocation> in the Response object (for marshalling), and populates List<ResourceStatus> and List<ResourceLocation> based on the ResourceStatusLocations objects during unmarshal. Something like this:
    public class RSLAttributeAccessor extends AttributeAccessor {
        public Object getAttributeValueFromObject(Object object) throws DescriptorException {
            ArrayList<ResourceStatusLocations> rslList = new ArrayList<ResourceStatusLocations>();
            Response resp = (Response) object;
            // build a list of ResourceStatusLocations using the Response object's ResourceStatus and ResourceLocation lists
            for (int i=0; i<resp.rs.size(); i++) {
                rslList.add(new ResourceStatusLocations(resp.rs.get(i), resp.rl.get(i)));
            return rslList;
        public void setAttributeValueInObject(Object object, Object value) throws DescriptorException {
            ArrayList<ResourceStatus> rsList = new ArrayList<ResourceStatus>();
            ArrayList<ResourceLocation> rlList = new ArrayList<ResourceLocation>();
            ArrayList<ResourceStatusLocations> rslList = (ArrayList<ResourceStatusLocations>) value;
            // build ResourceStatus and ResourceLocation lists using the given ResourceStatusLocations
            for (ResourceStatusLocations rsls : rslList) {
                rsList.add(rsls.rs);
                rlList.add(rsls.rl);
            resp.rs = rsList;
            resp.rl = rlList;
        public void initializeAttributes(Class descriptorClass) throws DescriptorException {
            // do nothing as the attribute doesn't really exist
Using this configuration I can successfully unmarshal from/marshal to this instance document:
    <remc:Response xmlns:common="mycommonuri" xmlns:remc="myuri">
        <remc:Location>
          <common:id>AAA</common:id>
          <common:Coordinate>
        <common:Y>5.0</common:Y>
        </remc:Location>
        <remc:Location>
          <common:id>BBB</common:id>
          <common:Coordinate>
        <common:Y>7.0</common:Y>
        </remc:Location>
    </remc:Response>
--Dave
[Updated on: Tue, 08 June 2010 14:37] by Moderator
Previous Topic:eclipselink doesn't find my persistence.xml
Next Topic:Problem on EclipseLink JPA Weaving using Toplink session.xml, project.xml as JPA Source
Current Time: Sat Jul 19 04:39:11 EDT 2025
Powered by FUDForum. Page generated in 0.02704 seconds
