Home » Eclipse Projects » Equinox » PDE ignores p2.inf(Building a rcp-product, PDE doesn't generate profile-file using p2.inf)
PDE ignores p2.inf [message #537150] Tue, 01 June 2010 09:14 Go to next message
since three days I'm trying to make our rcp client (3.5) p2 ready...
First I generated features for all plug-ins we created. Then I created an update site and changed the product to "feature-based".
The exported product is runnable. So far, so good.
Now I'm trying to add a headless update to the rcp client.
So I found this tutorial:
http://www.ralfebert.de/blog/eclipsercp/p2_updates_tutorial/
I downloaded and embedded the plug-in linked in the paragraph "Updating on application". After starting the client no progress monitor popped up. I debugged the "checkForUpdates" method and found out that
profileRegistry.getProfile(IProfileRegistry.SELF);
returns null.
So a profile-file is missing. (.\p2\org.eclipse.equinox.p2.engine\profileRegistry is empty)
After an internet research I found out, that I have to include a p2.inf file in the product's directory. But PDE ignores this file! No profile is generated when I export the product.
If I add syntax errors in this file, PDE doesn't bring an error. So it ignores this file completely!
What am I doing wrong?
Thanks in advance!
Roberto
Re: PDE ignores p2.inf [message #537235 is a reply to message #537150] Tue, 01 June 2010 11:57 Go to previous messageGo to next message
In e4 we have a product with a p2.inf (see [1] for
legacy-eclipse.product and p2.inf). I know we had to add a
p2.publish.product call to our customTargets.xml [2] and then use the
director to install our product IU.
[1]
http://dev.eclipse.org/viewcvs/index.cgi/e4/org.eclipse.e4.u i/examples/org.eclipse.e4.ui.examples.legacy.workbench/
[2]
http://dev.eclipse.org/viewcvs/index.cgi/e4/releng/org.eclip se.e4.builder/builder/general/customTargets.xml?view=co& content-type=text/plain
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: PDE ignores p2.inf [message #537274 is a reply to message #537150] Tue, 01 June 2010 14:26 Go to previous messageGo to next message
Make sure you check the box "Generate Metadata Repository" in the product
export wizard.
You don't need a p2.inf file, what you need is for the product to be
properly installed and configured for p2. This is done automatically for
you when you check the metadata box during export.
If you don't check that option then you get a plain old fashion product that
doesn't have the required configuration to properly use p2.
-Andrew
Roberto wrote:
> update site and changed the product to "feature-based". The exported
> profileRegistry.getProfile(IProfileRegistry.SELF); returns null.
> generated when I export the product. If I add syntax errors in this file,
> Thanks in advance!
> Roberto
Re: PDE ignores p2.inf [message #537450 is a reply to message #537274] Wed, 02 June 2010 09:51 Go to previous messageGo to next message
With the "Generate Metadata Repository" the profile is generated, thank you!
But now I've got another problem and a question:
The problem is:
The ProvisioningPlan runs into an error.
if (plan.getStatus().getSeverity() != IStatus.ERROR)
is false...
I can't find the reason Sad
The declaration part of the plan object:
ProfileChangeRequest changeRequest = new ProfileChangeRequest(profile);
changeRequest.removeInstallableUnits((IInstallableUnit[]) iusWithUpdates.toArray(new IInstallableUnit[iusWithUpdates.size()]));
changeRequest.addInstallableUnits((IInstallableUnit[]) replacementIUs.toArray(new IInstallableUnit[replacementIUs.size()]));
ProvisioningPlan plan = planner.getProvisioningPlan(changeRequest, pc, null);
The question is:
I have got a feature based product. But the updater checks the version of every feature and every plugin. I thought that only the feature version numbers are checked in a feature based product?
Roberto
Andrew Niefer wrote on Tue, 01 June 2010 14:26
export wizard.
-Andrew
Roberto wrote:
[Updated on: Wed, 02 June 2010 10:07] by Moderator
Re: PDE ignores p2.inf [message #542813 is a reply to message #537150] Sat, 26 June 2010 06:32 Go to previous message
The problem was that if you export the product with the jre it also adds the jre to the repository and tries to update the jre (which is not possibly while using the jre Very Happy). So you need to export without a jre and add the jre folder manually.
Because of a bug in eclipse you need to install Eclipse again to build a product without jre with PDE (it ignores the checkbox when exporting jre is selected once).
Very buggy the whole p2 manager Evil or Very Mad
Previous Topic:Stuck on Equinox Aspects Quickstart Guide
Next Topic:DS and Spring beans
Current Time: Sat Jul 19 01:17:45 EDT 2025
Powered by FUDForum. Page generated in 0.03313 seconds
