Home » Language IDEs » PHP Development Tools (PDT) » Autocomplete for PHP variables and methods(I can't get variable autocompletion or method autocompletion to work. Please, please help if you can)
Autocomplete for PHP variables and methods [message #537188] Tue, 01 June 2010 11:03 Go to next message
Hi everyone
I'm really sorry if this has been answered elsewhere but I have been googling and searching on here for ages...
I am trying to use PDT 2 Helios (Build id: 20100506-2000) on Mac OSX 10.6 - this is intended as a replacement for my old PHP IDE - Zend Studio 5.5. I've got the standard PDT install and have added on RSE (Remote system Explorer).
I don't seem to be able to get Eclipse to do PHP variable name completion - e.g. I have a variable elsewhere on the script or an included script called for example $test_variable and I wanted to have Eclipse suggest "$test_variable" when I start typing e.g. "$tes". All Eclipse seems to do is complete built-in variables e.g. $_SERVER["REMOTE_HOST"].
Equally, I cannot get Eclipse to autocomplete my method names etc. Zend did a cracking job of this, even offering hints for the method parameters without needing to add comments to the method.
Am I missing something obvious? I read on a web page that I need to start a new project then change a setting on the project but I can't find any relevant settings.
Any help would be massively appreciated and apologies again if these questions have been answered elsewhere, if so, please point me in the right direction and i'll get to it.
Cheers
Neil
[Updated on: Tue, 01 June 2010 11:04] by Moderator
Re: Autocomplete for PHP variables and methods [message #537419 is a reply to message #537188] Wed, 02 June 2010 08:13 Go to previous messageGo to next message
Hi all
A slight update...Now variable name autocompletion is kind of working. I didn't change any settings but today I am getting some autocompletion but I am seeing the same variables repeated many times in the popup...but, it does work so it's a small improvement,
Any help or pointers to info would be very gratefully appreciated.
Neil
Re: Autocomplete for PHP variables and methods [message #539055 is a reply to message #537188] Wed, 09 June 2010 09:54 Go to previous messageGo to next message
Does anyone have any ideas on this please? Anything at all? Otherwise i'm going to abandon Eclipse and go back to Zend studio...
Re: Autocomplete for PHP variables and methods [message #540282 is a reply to message #537188] Tue, 15 June 2010 10:18 Go to previous messageGo to next message
Greetings,
If your Project is not a PHP Project, try
File > New > PHP Project
HTH
-Rob B
Re: Autocomplete for PHP variables and methods [message #540291 is a reply to message #540282] Tue, 15 June 2010 10:38 Go to previous messageGo to next message
Hi Rob
Thanks for the reply but unfortunately it it already a PHP project...
Cheers
Re: Autocomplete for PHP variables and methods [message #548291 is a reply to message #537188] Wed, 21 July 2010 07:40 Go to previous message
Hi. Maybe it will help
http://www.eclipse.org/forums/index.php?t=rview&goto=486 493&th=154431#msg_486493
Previous Topic:debug / edit existing web applications on the local server
Next Topic:Debugger stops (breakpoints) at apparently completely random lines.
Current Time: Wed Jul 23 11:22:49 EDT 2025
Powered by FUDForum. Page generated in 1.06262 seconds
