Corrupt JAR, error while reading: midlet/MIDlet.class [message #535326] |
Sat, 22 May 2010 06:32  |
Hi everyone,
I finally managed to get around the compile errors, now its running the apps that is the problem. After SVN checkout it works fine, but after some code changes it just says
Installing suite from: http://127.0.0.1:60591/MIDlet.jad
*** Error ***
A problem occured during deploying application from http://127.0.0.1:60591/MIDlet.jad
Reason:
I've tried with many different J2ME projects that I have on my SVN repository, and most of them work after a clean checkout, sometimes i even have to remove my workspace to get it to work again. What Im i doing wrong? The the class is there, and everything in the build path is set up correctly. Im using J2ME SDK 3.0 with the latest version of Eclipse with MTJ on OSX (Snow Leopard)
I tried to google this, but no one seem to have a explanation of whats going wrong.
Please help me out here, I thought the switch from Ubuntu (where things like this never happened) to OS X would be easy.
Thanks in advance.
FUDForum. Page generated in 0.03210 seconds
