Home » Modeling » TMF (Xtext) » Terminal Rules token definitions are unreachable
Terminal Rules token definitions are unreachable [message #537038] Tue, 01 June 2010 02:55 Go to next message
I am using Xtext 1.0.0 RC1 and I am working on the definition of some terminal rules inside the grammar file.
Using a terminal rule like the following, no problem.
terminal COMPONENTTYPE:
	'aaaa'|'bbbb'
If I declare a terminal rule like the following one:
terminal INPUTOUTPUT:
	'input'|'output'
This is the warning message that appears:
937  [main] INFO  ipse.xtext.generator.LanguageConfig  - generating infrastructure for .../tdsl.Tdsl with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, ParseTreeConstructorFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, JavaValidatorFragment, ImportNamespacesScopingFragment, QualifiedNamesFragment, BuilderIntegrationFragment, FormatterFragment, LabelProviderFragment, TransformerFragment, OutlineNodeAdapterFactoryFragment, QuickOutlineFragment, QuickfixProviderFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment
warning(208): ../tdsl/parser/antlr/internal/InternalTdsl.g:2370:1: The following token definitions are unreachable: RULE_INPUTOUTPUT
14091 [main] INFO  or.validation.JavaValidatorFragment  - executing generate for org.eclipse.xtext.generator.validation.JavaValidatorFragment
warning(208): ../tdsl/ui/contentassist/antlr/internal/InternalTdsl.g:8289:1: The following token definitions are unreachable: RULE_INPUTOUTPUT
16419 [main] INFO  .emf.mwe2.runtime.workflow.Workflow  - Done.
is there any explanation to this behavior?
Re: Terminal Rules token definitions are unreachable [message #537067 is a reply to message #537038] Tue, 01 June 2010 04:47 Go to previous messageGo to next message
Hi Mattia,
do you use the keyword 'input' or 'output' anywhere in your grammar
besides the terminal rule?
Sebastian
Am 01.06.10 08:55, schrieb Mattia Fazzini:
> 'aaaa'|'bbbb'
> 'input'|'output'
> warning(208):
> ../tdsl/ui/contentassist/antlr/internal/InternalTdsl.g:8289: 1: The
Re: Terminal Rules token definitions are unreachable [message #537073 is a reply to message #537067] Tue, 01 June 2010 05:00 Go to previous messageGo to next message
Yes I do, in fact I was thinking that was the problem.
If this is the problem, why just a warning message and not an error message?
Thank you.
Mattia.
Re: Terminal Rules token definitions are unreachable [message #537080 is a reply to message #537073] Tue, 01 June 2010 05:21 Go to previous messageGo to next message
Mattia Fazzini wrote on Tue, 01 June 2010 05:00
Thank you.
Mattia.
Those messages are launched by ANTLR itself when compiling the grammar and not by xText as xText only generates the grammar then compiled by ANTLR so I think you gotta ask the ANTLR guys about this.
The explanation is clear though as it's not a blocking error so it's only a warning.
Re: Terminal Rules token definitions are unreachable [message #537089 is a reply to message #537073] Tue, 01 June 2010 05:14 Go to previous messageGo to next message
Hi Mattia,
the warnings are produced by Antlr. I guess its not an error because
it's sometimes okay to have syntactically conflicting terminal rules -
especially in combination with syntactic or semantic predicates.
Sebastian
Am 01.06.10 11:00, schrieb Mattia Fazzini:
> message?
> Thank you.
> Mattia.
Re: Terminal Rules token definitions are unreachable [message #537328 is a reply to message #537089] Tue, 01 June 2010 21:27 Go to previous message
Thank you for the information, I agree. But on the practical point of view, the DSL does not work. So, this is why I was a bit perplexed about it. However is not a problem.
Maybe a check message inside the editor should be really helpful. But I now this behavior does not depends from Xtext but from ANTLR.
Anyway thank you again.
Mattia.
Previous Topic:How to get the path of workspace ?
Next Topic:ANTLR Works question
Current Time: Fri Sep 19 13:52:10 EDT 2025
Powered by FUDForum. Page generated in 0.06453 seconds
