Home » Modeling » TMF (Xtext) » Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #537034] Tue, 01 June 2010 02:24 Go to next message
(replying to eclipse.modeling.tmf, which is where Xtext is discussed)
Frank Kuehnlenz schrieb:
> My existing ecore model has several packages:
> - root_package
> -- package_A
> -- package_B
> -- package_C
> and within package A classes from package B and C are referenced.
> Now I used the project creation wizard "Xtext Project From Existing
> Ecore Models" with the root_package as default package.
If you can split them up, i.e. one file per EPackage, I strongly suggest
to do so. Nested packages tend to complicate things.
> The generated xtext file contains now three imports:
> import "platform:/resource/testProject/test.ecore" as package_A
> import "platform:/resource/testProject/test.ecore" as package_B
> import "platform:/resource/testProject/test.ecore" as package_C
That's a bug in the wizard (please file a bug report).
You need to add the fragment part to the URIs. They should looke like
this:
platform:/resource/testProject/test.ecore#//package_A
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #537152 is a reply to message #537034] Tue, 01 June 2010 09:21 Go to previous messageGo to next message
Sure. Sorry.
>> - root_package
>> -- package_A
>> -- package_B
>> -- package_C
Thank you for this hint. I will have a look and try it. Maybe this is
related to my current problem (see below).
OK, reported as Bug 315193.
> this:
Thanks, that works. The xtext file is now free of error markers.
But I have now a problem on executing the MWE workflow:
15 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems
instantiating module expl.TextEditor:
java.lang.RuntimeException: Problems instantiating module
expl.TextEditor: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runne r.java:73)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runne r.java:52)
at
org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Lau ncher.java:74)
at
org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2La uncher.java:35)
Caused by: org.eclipse.emf.common.util.WrappedException:
at
org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$ 1.setValue(SettingProviderImpl.java:56)
at
org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.in ternalApplyAssignments(Mwe2ExecutionEngine.java:127)
at
org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.in Case(Mwe2ExecutionEngine.java:102)
at
at
at
org.eclipse.xtext.util.PolymorphicDispatcher.invoke(Polymorp hicDispatcher.java:259)
at
org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.in ternalSwitch(Mwe2ExecutionEngine.java:56)
at
org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.in ternalApplyAssignments(Mwe2ExecutionEngine.java:126)
at
at
at
at
at
at
org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.in Case(Mwe2ExecutionEngine.java:69)
at
at
at
at
at
org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.cr eate(Mwe2ExecutionEngine.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runne r.java:71)
... 3 more
Caused by: java.lang.reflect.InvocationTargetException
at
at
at
org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$ 1.setValue(SettingProviderImpl.java:54)
... 28 more
Caused by: org.eclipse.emf.mwe.core.ConfigurationException: Couldn't
find an interface ExperimentationLanguage.ExperimentationLanguagePackage
at
org.eclipse.emf.mwe.utils.StandaloneSetup.addRegisterGenerat edEPackage(StandaloneSetup.java:160)
... 33 more
All the best,
Frank
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #537159 is a reply to message #537152] Tue, 01 June 2010 09:58 Go to previous messageGo to next message
> at
> ... 33 more
The cause of the extension states that it can't find the interface you
configured for
StanaloneSetup {
registerGeneratedEPackage =
"ExperimentalLanguage.ExperimentalLanguagePackage"
Does that interface exist?
Sven
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #537191 is a reply to message #537159] Tue, 01 June 2010 10:52 Go to previous messageGo to next message
Hi Sven,
>> at
>> ... 33 more
> configured for
> StanaloneSetup {
well, at the moment I don't really see, how things are related.
What is the schema for the value of registerGeneratedEPackage?
Is it the Namespace prefix extended by the name and "Package"?
In my simple example 'ExperimentationLanguage' would be the root_package.
Assuming the schema above and this relation, than the part of the
configuration for the MWE workflow for my example classes would look
like this:
Workflow {
bean = StandaloneSetup {
platformUri = "${runtimeProject}/.."
registerGeneratedEPackage = "root_package.Root_packagePackage"
registerGeneratedEPackage = "root_package.package_A.Package_APackage"
registerGeneratedEPackage = "root_package.package_B.Package_BPackage"
registerGeneratedEPackage = "root_package.package_C.Package_CPackage"
I just removed the line 'registerGeneratedEPackage =
"root_package.Root_packagePackage"' from this configuration and now the
workflow can be executed and it generates the editor.
But using the editor causes now the following error:
An internal error occurred during: "XtextReconcilerJob".
java.lang.IllegalStateException: Unresolved proxy
http:///root_package.package_A.ecore#//package_A/SomeClassIn A Make sure
the EPackage has been registered.
All the best,
Frank
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #537224 is a reply to message #537191] Tue, 01 June 2010 11:41 Go to previous messageGo to next message
Addition and correction:
> http:///root_package/package_B.ecore#//package_A/SomeClassIn A Make sure
Having a closer look: There is something more strange, because the URI
contains different package names.
There is a use-relation between the classes in the packages: package_A
uses package_B.
Caused by: java.lang.IllegalStateException: Unresolved proxy
at
org.eclipse.xtext.parser.DefaultEcoreElementFactory.create(D efaultEcoreElementFactory.java:55)
at
expl.parser.antlr.internal.InternalTextEditorParser.ruleAntS criptTask(InternalTextEditorParser.java:152)
at
expl.parser.antlr.internal.InternalTextEditorParser.entryRul eAntScriptTask(InternalTextEditorParser.java:89)
at
at
at
org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.p arse(AbstractInternalAntlrParser.java:492)
... 15 more
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #537341 is a reply to message #537191] Wed, 02 June 2010 02:15 Go to previous messageGo to next message
> Hi Sven,
>>> at
>>> ... 33 more
>> configured for
>> StanaloneSetup {
It should be the qualified name of the generated Java interface for your
EPackage.
Sven
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #537342 is a reply to message #537224] Wed, 02 June 2010 02:16 Go to previous messageGo to next message
> uses package_B.
The cross references between the Ecore packages shouldn't be done using
nsURIs but platform:/resource uris. How did you create the ecore model?
Sven
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #537439 is a reply to message #537342] Wed, 02 June 2010 09:01 Go to previous messageGo to next message
Am 02.06.2010 08:16, schrieb Sven Efftinge:
>> uses package_B.
I create my ecore-model out of an UML source (exported by MagicDraw) by
using the UML2 Extender SDK that integrates into the EMF Project
creation wizard.
(The ecore model is also used for CDO and has maybe some additional
properties)
Frank
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #537592 is a reply to message #537439] Thu, 03 June 2010 00:30 Go to previous messageGo to next message
It is very untypical to use nsURIs to reference other EPackages.
You might be able to colve this by registering all (sub)packages using
the StandaloneSetup class.
Sven
>>> uses package_B.
> creation wizard.
> properties)
> Cheers,
> Frank
Re: [xtext] "EPackage is used twice" or How to import several packages of the same ecore m [message #538358 is a reply to message #537592] Mon, 07 June 2010 09:02 Go to previous message
Am 03.06.2010 06:30, schrieb Sven Efftinge:
It's just generated stuff out of the MagicDraw export.
I tried to register the EPackage classes manually using this way (maybe
wrong) without a positive effect:
public class TextEditorStandaloneSetup extends
TextEditorStandaloneSetupGenerated{
public static void doSetup() {
new TextEditorStandaloneSetup().createInjectorAndDoEMFRegistrati on();
EPackage.Registry.INSTANCE.put("http:///root_package/package_A.ecore#//package_A/",
root_package.package_A.Package_APackage.eINSTANCE);
EPackage.Registry.INSTANCE.put("http:///root_package/package_B.ecore#//package_B/",
root_package.package_B.Package_BPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put("http:///root_package/package_C.ecore#//package_C/",
root_package.package_C.Package_CPackage.eINSTANCE);
However, if I do not use any subpackages in my ecore-model and therefore
have a flat hierarchy, than it's working fine.
All the best,
Frank
>>>>> sure
>>>> uses package_B.
>>>> sure
>> creation wizard.
>> properties)
>> Cheers,
>> Frank
Previous Topic:left recursion
Next Topic:Deactivate backslash as escape character?
Current Time: Fri Sep 26 00:12:15 EDT 2025
Powered by FUDForum. Page generated in 0.08113 seconds
