Home » Archived » Buckminster » svn+ssh key file
svn+ssh key file [message #536920] Mon, 31 May 2010 09:54 Go to next message
Hello everybody,
I am trying to get rid of svn authentication errors in a headless
Buckminster build (Hudson-driven) with svn+ssh access scheme using private
key files.
I can't cope with getting the credentials recognized, tried with subversive
as well as subclipse.
I assume the problem is that the repository user is not the same one as the
hudson user, so that the private key file is not found. Is there a way to
specify the key file ?
My rmap spec looks like this:
<uri
format="svn+ssh://{0}@{1}/trunk/{2}?moduleAfterTag&amp;moduleAfterBranch">
<bc:propertyRef key="my.svn.user" />
<bc:propertyRef key="my.svn.repository" />
<bc:propertyRef key="buckminster.component" />
</uri>
Error with subversive:
org.eclipse.team.svn.core.connector.SVNConnectorAuthenticati onException:
svn: Authentication required for '<uri>'
Any help appreciated.
Axel
Re: svn+ssh key file [message #536929 is a reply to message #536920] Mon, 31 May 2010 10:10 Go to previous messageGo to next message
Hi Axel,
you should be able to make it work by:
- making sure you are using the SVNKit
- and then following the instructions given at:
http://svnkit.com/kb/user-guide-config-settings.html in the section
"SVN+SSH authentication with private key in Eclipse"
Note that I haven't tested that approach though, so please don't hold me
responsible if it doesn't work out.
HTH
Michal
Dne 31.5.2010 15:54, Axel Guckelsberger napsal(a):
> Hello everybody,
> key files.
> <uri
> </uri>
> Regards,
> Axel
Re: svn+ssh key file [message #536935 is a reply to message #536929] Mon, 31 May 2010 10:46 Go to previous messageGo to next message
Hi Michal,
thanks for your reply.
> Hi Axel,
How can I ensure that for the headless eclipse used during the build?
Just started to play with what you've written at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=310204#c3 (thanks to Henrik
for pointing this out), but no success yet.
Greetings
Axel
> HTH
> Michal
>> Hello everybody,
>> private key files.
>> subversive as well as subclipse.
>> the hudson user, so that the private key file is not found. Is there a
>> way to specify the key file ?
>> <uri
>> </uri>
>> Regards,
>> Axel
Re: svn+ssh key file [message #536942 is a reply to message #536935] Mon, 31 May 2010 11:24 Go to previous messageGo to next message
Dne 31.5.2010 16:46, Axel Guckelsberger napsal(a):
> Hi Michal,
>> Hi Axel,
Headless Buckminster bundles the SVNKit by default (both with
Subversiove and Subclipse). So you should be fine.
This unfortunately won't work with SVNKit, as it uses yet another java
implementation of SSH than the preferences mentioned in the bugzilla are
targeted at.
You will need to set the properties mentioned at the
http://svnkit.com/kb/user-guide-config-settings.html page.
If you use the Buckminster plugin for Hudson
(http://wiki.hudson-ci.org/display/HUDSON/Buckminster+PlugIn) then you
need to supply those properties to your "Run Buckminster" build step as
"JVM Arguments" in the "Advanced Options" section. Something like this:
-Dsvnkit.ssh2.key=/path/to/private/key/file
HTH
Michal
Re: svn+ssh key file [message #536945 is a reply to message #536942] Mon, 31 May 2010 11:40 Go to previous messageGo to next message
Thank you very much! It works - finally :-)
Axel
>> Hi Michal,
>>> Hi Axel,
> targeted at.
> HTH
> Michal
Re: svn+ssh key file [message #536965 is a reply to message #536945] Mon, 31 May 2010 13:14 Go to previous messageGo to next message
The following exceptions do still occur during the cquery import. Don't know
whether it could be a bug, maybe it can be of interest for you.
http://pastebin.com/k3RMHCf3
Looks like the team provider wants to open a ui element.
Greetings
Axel
> Regards
> Axel
>>> Hi Michal,
>>>> Hi Axel,
>>> Henrik for pointing this out), but no success yet.
>> targeted at.
>> HTH
>> Michal
Re: svn+ssh key file [message #537016 is a reply to message #536965] Mon, 31 May 2010 18:44 Go to previous message
I think you should log that issue.
- henrik
> Greetings
> Axel
>> Regards
>> Axel
>>>> Hi Michal,
>>>>> Hi Axel,
>>> targeted at.
>>> HTH
>>> Michal
Previous Topic:p2 build fails with java1.5 but works with 1.6
Next Topic:"authentication cancelled" error headless, but works in IDE
Current Time: Sat Jul 26 18:19:57 EDT 2025
Powered by FUDForum. Page generated in 0.49284 seconds
