Home » Archived » Buckminster » p2 build fails with java1.5 but works with 1.6
p2 build fails with java1.5 but works with 1.6 [message #536860] Mon, 31 May 2010 05:57 Go to next message
Hello All,
I am having a problem while building the update site using hudson and buckminster. It will be a great favour if some one can guide me in resolving this.
When i try to create a p2 update site and the build environment is set to Java 1.6 everything works fine, but as I switch it to 1.5 I get the following error :
ERROR: An internal error occurred during: "Installing". java.lang.IllegalArgumentException: Resolution not created using LocalReader at org.eclipse.buckminster.core.reader.LocalReaderType.getFixedLocation(LocalReaderType.java:50) at org.eclipse.buckminster.core.materializer.WorkspaceMaterializer.getMaterialization(WorkspaceMaterializer.java:68) at org.eclipse.buckminster.core.materializer.WorkspaceMaterializer.createBindSpec(WorkspaceMaterializer.java:241) at org.eclipse.buckminster.core.materializer.WorkspaceMaterializer.performInstallAction(WorkspaceMaterializer.java:198) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:164) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.delegateAndInstallRecursive(AbstractMaterializer.java:189) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.installRecursive(AbstractMaterializer.java:156) at org.eclipse.buckminster.core.materializer.AbstractMaterializer.performInstallActions(AbstractMaterializer.java:68) at org.eclipse.buckminster.core.materializer.InstallerJob.runInWorkspace(InstallerJob.java:52) at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Now the problem with our existing code is that its not been migrated yet for Java 1.6 and we don't want to do it just for this purpose.
Thanks a lot in advance.
Thanks and regards,
Nitesh
Re: p2 build fails with java1.5 but works with 1.6 [message #536869 is a reply to message #536860] Mon, 31 May 2010 06:40 Go to previous messageGo to next message
Hi Nitesh,
I'm running a Buckminster headless with Java 1.5 but I'm not able to reproduce this. Would it be possible for you to
create a reproduceable example and attach it to a bugzilla? Exactly what is it that you have installed and what type of
readers are deployed in the RMAP?
- thomas
On 05/31/2010 11:57 AM, nitesh wrote:
> Hello All,
> resolving this.
> following error :
> LocalReader at
> org.eclipse.buckminster.core.reader.LocalReaderType.getFixed Location(LocalReaderType.java:50)
> at
> org.eclipse.buckminster.core.materializer.WorkspaceMateriali zer.getMaterialization(WorkspaceMaterializer.java:68)
> at
> org.eclipse.buckminster.core.materializer.WorkspaceMateriali zer.createBindSpec(WorkspaceMaterializer.java:241)
> at
> org.eclipse.buckminster.core.materializer.WorkspaceMateriali zer.performInstallAction(WorkspaceMaterializer.java:198)
> at
> org.eclipse.buckminster.core.materializer.AbstractMaterializ er.installRecursive(AbstractMaterializer.java:164)
> at
> org.eclipse.buckminster.core.materializer.AbstractMaterializ er.delegateAndInstallRecursive(AbstractMaterializer.java:189 )
> at
> org.eclipse.buckminster.core.materializer.AbstractMaterializ er.installRecursive(AbstractMaterializer.java:156)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.buckminster.core.materializer.AbstractMaterializ er.performInstallActions(AbstractMaterializer.java:68)
> at
> org.eclipse.buckminster.core.materializer.InstallerJob.runIn Workspace(InstallerJob.java:52)
> at
> org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
> LocalReader
> Thanks and regards,
> Nitesh
Re: p2 build fails with java1.5 but works with 1.6 [message #536870 is a reply to message #536869] Mon, 31 May 2010 06:51 Go to previous message
that problem sounds an aweful lot like this one:
http://www.eclipse.org/forums/index.php?t=msg&th=168194& amp;start=0&
Johannes
Previous Topic:"One or more certificates rejected" during create.product action
Next Topic:svn+ssh key file
Current Time: Fri Jul 25 21:47:12 EDT 2025
Powered by FUDForum. Page generated in 0.23902 seconds
