Home » Archived » BIRT » Birt upgrade openreports Resolved
Birt upgrade openreports Resolved [message #536812] |
Mon, 31 May 2010 03:20  |
OpenReports 3.20 use birt 2 3 2, Eclipse Helios Birt 2.6.0. The rptdesign files produced are not in same format. Eclipse Birt works to update the rptdesign 2 3.2 files.
I would like to update birt (2.3.2) OpenReport to deploy the files generated by eclipse 2.6.0.
Someone should do this or he would give me a track?
Many thank's.
[Updated on: Wed, 09 June 2010 03:19] by Moderator
Re: Birt upgrade openreports [message #550525 is a reply to message #550495] |
Fri, 30 July 2010 12:26   |
Originally posted by: headerhound.yahoo.co.uk
Jason Weathersby wrote:
> Can you post the error you are getting?
Snip
Ok, basically I replaced the 2.3.2 files with the 2.6 files I could see
a mapping for. so for Web_inf/lib I put these files in ...
17/06/2010 13:04 6,451,211 com.ibm.icu_4.2.1.v20100412.jar
09/06/2010 20:07 771,550 js.jar
17/06/2010 13:06 211,682
org.eclipse.emf.common_2.6.0.v20100614-1136.jar
17/06/2010 13:06 219,248
org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846.jar
17/06/2010 13:06 1,231,338
org.eclipse.emf.ecore_2.6.0.v20100614-1136.jar
and for Web_inf/platform/plugins ......
17/06/2010 13:05 138,224
org.eclipse.birt.chart.device.extension_2.6.0.v20100521.jar
17/06/2010 13:05 12,906
org.eclipse.birt.chart.device.pdf_2.6.0.v20100304.jar
17/06/2010 13:05 66,595
org.eclipse.birt.chart.device.svg_2.6.0.v20100527.jar
17/06/2010 13:05 58,472
org.eclipse.birt.chart.device.swt_2.6.0.v20100519.jar
17/06/2010 13:05 275,478
org.eclipse.birt.chart.engine.extension_2.6.0.v20100601.jar
17/06/2010 13:05 1,543,550
org.eclipse.birt.chart.engine_2.6.0.v20100607.jar
17/06/2010 13:05 253,199
org.eclipse.birt.chart.reportitem_2.6.0.v20100604.jar
17/06/2010 13:05 144,244
org.eclipse.birt.core.script.function_2.6.0.v20100524.jar
17/06/2010 13:05 429,213
org.eclipse.birt.core_2.6.0.v20100526.jar
17/06/2010 13:05 122,711
org.eclipse.birt.data.aggregation_2.6.0.v20100524.jar
17/06/2010 13:05 1,648,451
org.eclipse.birt.data_2.6.0.v20100524.jar
17/06/2010 13:05 26,910
org.eclipse.birt.report.data.oda.jdbc.dbprofile_2.6.0.v20100 524.jar
29/07/2010 21:46 <DIR>
org.eclipse.birt.report.data.oda.jdbc_2.6.0.v20100524
17/06/2010 13:05 21,845
org.eclipse.birt.report.data.oda.xml_2.6.0.v20100524.jar
17/06/2010 13:05 11,537
org.eclipse.birt.report.engine.dataextraction.csv_2.5.2.v201 00115.jar
17/06/2010 13:05 14,692
org.eclipse.birt.report.engine.dataextraction_2.5.2.v2010011 5.jar
17/06/2010 13:05 23,794
org.eclipse.birt.report.engine.emitter.config_2.6.0.v2010030 4.jar
17/06/2010 13:05 13,074
org.eclipse.birt.report.engine.emitter.excel.config_2.6.0.v2 0100527.jar
17/06/2010 13:05 11,853
org.eclipse.birt.report.engine.emitter.html.config_2.6.0.v20 100304.jar
17/06/2010 13:05 79,630
org.eclipse.birt.report.engine.emitter.html_2.6.0.v20100603. jar
17/06/2010 13:05 13,887
org.eclipse.birt.report.engine.emitter.pdf.config_2.6.0.v201 00512.jar
17/06/2010 13:05 28,567
org.eclipse.birt.report.engine.emitter.pdf_2.6.0.v20100513.j ar
17/06/2010 13:05 14,446
org.eclipse.birt.report.engine.emitter.postscript.config_2.6 .0.v20100512.jar
17/06/2010 13:05 60,385
org.eclipse.birt.report.engine.emitter.postscript_2.6.0.v201 00526.jar
17/06/2010 13:05 13,698
org.eclipse.birt.report.engine.emitter.ppt.config_2.6.0.v201 00512.jar
17/06/2010 13:05 27,293
org.eclipse.birt.report.engine.emitter.ppt_2.6.0.v20100429.j ar
17/06/2010 13:05 105,868
org.eclipse.birt.report.engine.emitter.prototype.excel_2.6.0 .v20100601.jar
17/06/2010 13:05 12,486
org.eclipse.birt.report.engine.emitter.wpml.config_2.6.0.v20 100512.jar
17/06/2010 13:05 65,822
org.eclipse.birt.report.engine.emitter.wpml_2.6.0.v20100520. jar
org.eclipse.birt.report.engine.fonts_2.6.0.v20100428
17/06/2010 13:05 26,615
org.eclipse.birt.report.engine.script.javascript_2.6.0.v2010 0408.jar
17/06/2010 13:05 2,612,238
org.eclipse.birt.report.engine_2.6.0.v20100609.jar
17/06/2010 13:05 260,529
org.eclipse.birt.report.item.crosstab.core_2.6.0.v20100531.j ar
17/06/2010 13:05 165,874
org.eclipse.birt.report.model.adapter.oda_2.6.0.v20100528.ja r
17/06/2010 13:05 2,740,417
org.eclipse.birt.report.model_2.6.0.v20100603.jar
org.eclipse.core.runtime.compatibility.registry_3.3.0.v20100 520
29/07/2010 21:47 <DIR> org.mozilla.rhino_1.7.1.v20090608
29/07/2010 21:47 <DIR> org.w3c.sac_1.3.0.v20070710
The war built ok but when I deploy I get
30-Jul-2010 16:57:48 org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance
of class org.springframework.web.context.ContextLoaderListener
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'birtProvider' defined in ServletContext resource
[/WEB-INF/applicationContext.xml]: Instantiation of bean failed; nested
exception is org.springframework.beans.BeanInstantiationException: Could
not instantiate bean class [org.efs.openreports.providers.BirtProvider]:
Constructor threw exception; nested exception is
Caused by: org.springframework.beans.BeanInstantiationException: Could
at
org.efs.openreports.providers.BirtProvider.startBirtEngine(B irtProvider.java:121)
at
org.efs.openreports.providers.BirtProvider.<init>(BirtProvider.java:75)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
etc etc
I had hoped to get it going without refactoring src code .....
Re: Birt upgrade openreports [message #550564 is a reply to message #550525] |
Fri, 30 July 2010 15:50  |
The Web_inf/lib directory should contain all the jars in the 2.6
runtime/ReportEngine/lib not just the five you posted. You also should
replace the Web_inf/platform/configuration directory with the one in the
runtime. Verify that that it only contains config.ini. I am not
certain this will fix the problem but its worth a try.
Jason
> Snip
> 17/06/2010 13:06 211,682 org.eclipse.emf.common_2.6.0.v20100614-1136.jar
> 17/06/2010 13:06 219,248 org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846.jar
> 17/06/2010 13:06 1,231,338 org.eclipse.emf.ecore_2.6.0.v20100614-1136.jar
> 17/06/2010 13:05 429,213 org.eclipse.birt.core_2.6.0.v20100526.jar
> 17/06/2010 13:05 1,648,451 org.eclipse.birt.data_2.6.0.v20100524.jar
> 29/07/2010 21:46 <DIR> org.eclipse.birt.report.engine.fonts_2.6.0.v20100428
> at
> at org.efs.openreports.providers.BirtProvider.<init>(BirtProvider.java:75)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
> etc etc
Current Time: Sat Jul 26 19:58:36 EDT 2025
Powered by FUDForum. Page generated in 0.04853 seconds
