Home » Modeling » M2T (model-to-text transformation) » [Xtend] Lists in JAVA extensions
[Xtend] Lists in JAVA extensions [message #536729] Sun, 30 May 2010 09:31 Go to next message
Hi there,
for a Java internal calculation, I need to either
* pass a List as parameter to a JAVA extension or
* get a List as return value from a JAVA extension
How do I do those?
The Xtend reference does not say anything about return values of Java
extension methods at all. So how are they handled?
When I try one of these, I always get
"[Callable not found] - getPorts : getPorts"
--- xtend file
Void getPorts(List ports) :
JAVA my.PtolemyHelper.getPorts(java.util.List);
--- java file
public static void getPorts(java.util.List ports){
System.out.println("test");
It's the same when I change java.util.List with
org.eclipse.emf.common.util.EList.
So how can I pass an Xtend List to Java? And how could I return a Java
list to Xtend?
Hauke
Re: [Xtend] Lists in JAVA extensions [message #536732 is a reply to message #536729] Sun, 30 May 2010 10:40 Go to previous messageGo to next message
Hello Hauke,
the extension / java class you defined looks ok and work in my hello world example.
The exception you get hints to some configuration / metamodel / classpath problem so please veryfy that the configuration is correct and that everything can be found on the classpath.
Regards, Christian
Re: [Xtend] Lists in JAVA extensions [message #536733 is a reply to message #536729] Sun, 30 May 2010 10:52 Go to previous messageGo to next message
Hi Hauke,
this might solve your problem.
Xtend:
List[Node] getPassedNodes(List[Node] nodes): JAVA javacode.Routing.getPassedNodes(java.util.List);
Java:
package javacode;
import org.eclipse.emf.common.util.BasicEList;
public class Routing {
	public static List<Node> getPassedNodes(List<Node> nodes) {
		List<Node> passedNodes;
		passedNodes = new BasicEList<Node>();
		passedNodes.addAll(nodes);
		return passedNodes;
It's important that you specify the return type of your Xtend function even if you don't need to specify it for your Java method in Xtend.
As Alternative to BasicEList you can use any List implementation such as ArrayList.
Gerd
[Updated on: Sun, 30 May 2010 10:53] by Moderator
Re: [Xtend] Lists in JAVA extensions [message #536752 is a reply to message #536733] Sun, 30 May 2010 13:09 Go to previous messageGo to next message
Hi Gerd,
In the case of Java extensions specifying return types is mandatory.
But Hauke used void/Void as the return type which is perfectly ok.
So I don't think that your suggestion solves the issue.
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [Xtend] Lists in JAVA extensions [message #536753 is a reply to message #536729] Sun, 30 May 2010 13:10 Go to previous messageGo to next message
Hauke,
how and from where do you call the extension?
Sven
Re: [Xtend] Lists in JAVA extensions [message #536771 is a reply to message #536753] Sun, 30 May 2010 15:15 Go to previous messageGo to next message
Hmm... not sure I understand the question. I would say "the normal way"...
I use the extension as a model-to-model transformation from a Workflow
that I instanciated programmatically in Java code. I execute the
transformation by an Eclipse UI command handler.
The Xtend file is correctly found and all the rest of the transformation
is running. The static Java method is in a Java class in the same plugin
as the Xtend file and the command handler. A simple "test(String)" Java
extension in the same file works without problems. Hence it must be a
problem with the parameters somehow.
Hauke
Re: [Xtend] Lists in JAVA extensions [message #536780 is a reply to message #536771] Sun, 30 May 2010 17:36 Go to previous messageGo to next message
I just tested it in a normal java process using the example the wizard
generates.
I was able to define the following two methods
List[Entity] entities(Model this) :
JAVA metamodel.Helper.getEntities(org.eclipse.emf.ecore.EObject);
Model model(List[Entity] this) :
JAVA metamodel.Helper.getModel(org.eclipse.emf.common.util.EList) ;
which were bound to the following two Java signatures:
public static EList<EObject> getEntities(EObject obj)
public static EObject getModel(EList<EObject> list)
No problem.
It seems that it has something to do with the OSGi context.
Sven
> Cheers,
> Hauke
Re: [Xtend] Lists in JAVA extensions [message #536781 is a reply to message #536771] Sun, 30 May 2010 17:47 Go to previous messageGo to next message
It looks like it's at all no problem with passing lists, but with
another parameter (first I tried to reduce the example to a smaller
case, which seems to actually not show the problem):
--- xtend
Void test(EntityType entity) :
JAVA my.Test.test(my.metamodel.EntityType)
--- java
public static void test(EntityType test) {
System.out.println(test.getName());
Then I get the [Callable not found] error.
The generated my.metamodel code is in the same plugin. Is there a
problem with passing such custom metamodel objects?
A strange workaround is to wrap the EntityType parameter in a List. That
works.
Hauke
Re: [Xtend] Lists in JAVA extensions [message #536807 is a reply to message #536781] Mon, 31 May 2010 02:18 Go to previous messageGo to next message
> --- xtend
> --- java
What makes this type 'custom' (i.e. special)?
What kind of meta model do you use? I suspect that you face the problem
when running the generator. If that is the case, please share the
configuration of your workflow, especially the metaModel part.
Sven
Re: [Xtend] Lists in JAVA extensions [message #536931 is a reply to message #536807] Mon, 31 May 2010 10:30 Go to previous messageGo to next message
Well, its some instance object of my metamodel. So it's not really
special. But it's not a primitive.
I call it from a Java plugin in a command handler. If you want to see it:
http://rtsys.informatik.uni-kiel.de/trac/kieler/browser/trun k/plugins/de.cau.cs.kieler.core.model/src/de/cau/cs/kieler/c ore/model/util/XtendTransformationUtil.java?rev=5980
Hauke
Re: [Xtend] Lists in JAVA extensions [message #536983 is a reply to message #536931] Mon, 31 May 2010 15:08 Go to previous message
Mmhh.. could it be that the model consists of instances of a different
EPackage? I mean a different instance, maybe a dynamic?
>> problem when running the generator. If that is the case, please share
>> the configuration of your workflow, especially the metaModel part.
> Cheers,
> Hauke
Previous Topic:[Acceleo] How to generate code from Actions in Activity diagram in control flow order?
Next Topic:XPAND 1.0.0
Current Time: Wed Jul 23 01:56:27 EDT 2025
Powered by FUDForum. Page generated in 0.15883 seconds
