Home » Eclipse Projects » Eclipse Platform » CVS Fulle History
CVS Fulle History [message #536639] Sat, 29 May 2010 01:21 Go to next message
Is there any way to view history for a whole project or module from any of the Team CVS views?
Failing that, can anyone share the best way to get this information for Eclipse project CVS modeules? I don't mind dealing with console and text results if I have to but a GUI solution would be nice. Basically, I just wnat to go through my logs and find out the changes I've made -- all I need is the number and description. (Seems like it would be easy to do!)
thanks,
Miles
Re: CVS Fulle History [message #536673 is a reply to message #536639] Sat, 29 May 2010 13:13 Go to previous messageGo to next message
Sat, 29 May 2010 01:21:38 -0400, /Miles Parker/:
I'm not aware of such way, currently.
There's CVSps - Patchsets for CVS [1] utility which should generate
what you want. I would love to see a pre-compiled version of it
working on Windows without Cygwin.
I wonder, if Eclipse is able to generate such change sets
information in the Synchronize view, why it is not using for the
purpose of viewing module/directory history - may it would be too slow?
[1] http://www.cobite.com/cvsps/
Stanimir
Re: CVS Fulle History [message #536676 is a reply to message #536673] Sat, 29 May 2010 13:54 Go to previous messageGo to next message
Stanimir Stamenkov wrote on Sat, 29 May 2010 13:13
Yeah, that's what I was wondering too. I mean the information is obviously there and the team tools handle asynchronous updating very nicely. Looking at some old googled pages it seems like a feature like this might have been available in early versions.
Re: CVS Fulle History [message #536677 is a reply to message #536673] Sat, 29 May 2010 13:54 Go to previous messageGo to next message
Oh, and thanks for the link!
Re: CVS Fulle History [message #536679 is a reply to message #536673] Sat, 29 May 2010 13:56 Go to previous messageGo to next message
Sat, 29 May 2010 20:13:30 +0300, /Stanimir Stamenkov/:
I've found the following enhancement request:
"CVS History View for module not file"
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=53164>
However it is resolved as won't fix. It mentions a CVS Change Log
plugin:
http://cvschangelog.sourceforge.net/
I've now remembered I've used it long ago (I have really not used
CVS in a day job, even more for personal use, since more than 2
years, now).
> There's CVSps - Patchsets for CVS [1] utility which should generate what
> you want. I would love to see a pre-compiled version of it working on
> I wonder, if Eclipse is able to generate such change sets information in
> the Synchronize view, why it is not using for the purpose of viewing
You may checkout a copy of your project at its very first
revision/date, manually remove the sticky tags from the Entries
files in the CVS directories then issue a Synchronize with
Repository - Show Change Set information and you would get pretty
much the history of the module.
Stanimir
Re: CVS Fulle History [message #536680 is a reply to message #536679] Sat, 29 May 2010 14:11 Go to previous message
Sat, 29 May 2010 20:56:54 +0300, /Stanimir Stamenkov/:
> However it is resolved as won't fix. It mentions a CVS Change Log plugin:
You may also checkout the other page mentioned in the report:
http://dev.eclipse.org/viewcvs/index.cgi/platform-vcm-home/d ocs/online/html-cvs/cvs-community.html?view=co
It lists two more ChangeLog plugins you may try out.
Stanimir
Previous Topic:attach eclipse source
Next Topic:[DataBinding] Default Date Converter
Current Time: Wed Jul 23 07:25:24 EDT 2025
Powered by FUDForum. Page generated in 0.09055 seconds
