Home » Eclipse Projects » Buckminster dev » Headless buckminster commands broken in 3.6?
Headless buckminster commands broken in 3.6? [message #536378] Thu, 27 May 2010 17:17 Go to next message
it seems like the latest buckminster executable (obtained from the
http://download.eclipse.org/tools/buckminster/headless-3.6 update site) does
not understand the 'setpref' command, causing the Hudson job to fail.
Is this a bug or am I doing something wrong?
Axel
Re: Headless buckminster commands broken in 3.6? [message #536407 is a reply to message #536378] Fri, 28 May 2010 01:07 Go to previous messageGo to next message
Hi Alex,
The setpref command is not included in the product. It is added by the o.e.buckminster.core feature. Is that feature
installed?
HTH,
Thomas Hallgren
On 05/27/2010 11:17 PM, Axel Guckelsberger wrote:
> Hello,
> Regards,
> Axel
Re: Headless buckminster commands broken in 3.6? [message #536436 is a reply to message #536407] Fri, 28 May 2010 04:53 Go to previous messageGo to next message
Hi Thomas,
yes it is. In detail I installed the following headless features:
buckminster core, cvs, pde, subclipse.
For now I switched back to the headless version of 3.5 temporarily.
Axel
Thomas Hallgren wrote:
> Hi Alex,
> o.e.buckminster.core feature. Is that feature installed?
> HTH,
> Thomas Hallgren
>> Hello,
>> does not understand the 'setpref' command, causing the Hudson job to
>> fail. Is this a bug or am I doing something wrong?
>> Regards,
>> Axel
Re: Headless buckminster commands broken in 3.6? [message #536462 is a reply to message #536436] Fri, 28 May 2010 07:32 Go to previous messageGo to next message
Hi Axel,
I have no problems using 3.6. I just tried this:
[thhal@tada tmp]$ ../buildtools/director/director -r http://download.eclipse.org/tools/buckminster/headless-3.6 -p
Buckminster -d /home/thhal/tmp/buckminster -i org.eclipse.buckminster.cmdline.product -i
org.eclipse.buckminster.core.headless.feature.feature.group -roaming
Installing org.eclipse.buckminster.cmdline.product 1.2.0.r11425.
Installing org.eclipse.buckminster.core.headless.feature.feature.group 1.3.0.r11446.
Operation completed in 30095 ms.
[thhal@tada tmp]$ buckminster/buckminster setpref connectionRetryCount=2
connectionRetryCount set to the value '2'
What platform are you running on?
- thomas
On 05/28/2010 10:53 AM, Axel Guckelsberger wrote:
> Hi Thomas,
> Regards
> Axel
>> Hi Alex,
>> HTH,
>> Thomas Hallgren
>>> Hello,
>>> Regards,
>>> Axel
Re: Headless buckminster commands broken in 3.6? [message #536490 is a reply to message #536462] Fri, 28 May 2010 09:09 Go to previous messageGo to next message
Hi Thomas,
I coped with reproducing your example and it worked. I try to explain the
difference and what went wrong before. I am running this on a Ubuntu
machine.
If one calls the director like you did in the snippet below everything works
well. In my earlier attempts I did it in several single steps like shown in
the wiki:
1. director/director -r
http://download.eclipse.org/tools/buckminster/headless-3.6 -p Buckminster -d
TestFolder -i org.eclipse.buckminster.cmdline.product
2. TestFolder/buckminster install core headless feature
3. TestFolder/buckminster install the other ones
The problem here is that the features installed by buckminster are placed in
TestFolder/TestFolder so at the end there are two different p2 repositories.
Maybe caused by using relative target folders at this place.
After I tried your version successfully I installed the pde headless feature
with buckminster. This time it went into the correct folders.
Thanks for your help
Axel
> Hi Axel,
> [http://download.eclipse.org/tools/buckminster/headless-3.6 -p
> 1.3.0.r11446. Operation completed in 30095 ms.
> - thomas
>> Hi Thomas,
>> Regards
>> Axel
>>> Hi Alex,
>>> HTH,
>>> Thomas Hallgren
>>>> Hello,
>>>> Regards,
>>>> Axel
Re: Headless buckminster commands broken in 3.6? [message #536509 is a reply to message #536490] Fri, 28 May 2010 10:11 Go to previous message
Hi Axel,
for some reason using relative paths causes all kinds of weird side
effects, you should stick to absolute paths for the director application.
Johannes
Previous Topic:replace a plugin in buckminster
Next Topic:Problems with creating JNLP build of eclipse RCP product
Current Time: Fri Jul 18 16:44:19 EDT 2025
Powered by FUDForum. Page generated in 0.09719 seconds
