Home » Archived » M2M (model-to-model transformation) » create UML association using ownedEnd, ownedMEmber
create UML association using ownedEnd, ownedMEmber [message #536302] Thu, 27 May 2010 11:12 Go to next message
hi all, how can I create association from uml class,
the ownedEnd are as properties of that class
and what is different between ownedEnd and memberEnd
from op : UML!Class
op.hasStereotype('ObjectProperty')
using{
src : UML!Property = op.ownedAttribute -> select(e | e.hasStereotype('domain'));
dst : UML!Property = op.ownedAttribute -> select(e | e.hasStereotype('range')) ;
to ass : UML!Association(
name <- op.name,
ownedEnd <- Set{src , dst },
navigableOwnedEnd <- src ,
memberEnd <- Set{src , dst}
by this code only the association with no properties
[Updated on: Thu, 27 May 2010 11:13] by Moderator
Re: create UML association using ownedEnd, ownedMEmber [message #536320 is a reply to message #536302] Thu, 27 May 2010 12:04 Go to previous message
An association is completely different to a class, unless it is an
AssociationClass.
A normal association uses memberEnds to refewrences Property ends owned
by a Class.
However for nonnavigable links, the Class-owned Property does not exist
so the Association must own it via ownedEnd.
An AssociationClass enhances the link withy full class characteristics.
Read a good UML or OCL document.
Ed Willink
> Quote:
>> from op : UML!Class
>> using{
>> src : UML!Propert = op.ownedAttribute -> select(e |
>> dst : UML!Propert = op.ownedAttribute -> select(e |
>> name <- op.name,
>> memberEnd <- Set{src , dst} )
Previous Topic:Create a children for an element
Next Topic:[ATL] how to extends ATL language with own library ?
Current Time: Sat Jul 19 02:46:40 EDT 2025
Powered by FUDForum. Page generated in 0.06650 seconds
