Home » Eclipse Projects » DSDP - Target Management » can't share, import/export RSE profiles(Is there an easy way to share RSE profiles?)
can't share, import/export RSE profiles [message #536029] Wed, 26 May 2010 13:02 Go to next message
I have been looking to see if there is a way that one can share RSE profiles besides copying the contents of:
%workspace%\.metadata\.plugins\org.eclipse.rse.core\profiles \%profile_name%
When I reinstall eclipse or configure a machine for a new developer, I want them to have a set of company wide user defined actions, connections and filters. Some forums talk about copying anything under RemoteSystemConnections project in the workspace, but apparently that is not in the workspace anymore, probably was there in earlier versions of Eclipse.
Anybody can give me some direction? Would very much appreciate it.
Thanks a lot.
Kamal
Re: can't share, import/export RSE profiles [message #537852 is a reply to message #536029] Thu, 03 June 2010 16:31 Go to previous messageGo to next message
> of Eclipse.
> Thanks a lot.
> Kamal
Right now that is the only way to share a whole profile. DSDP/TM added
the ability to export a connection and its filters a few releases ago.
We're now beginning to get more interest for more flexible
export/import options, including the ability to export the property
sets used to define user-defined actions. This will likely involve new
export and import wizards for profiles. There are several bugzilla
items that relate to this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=277163
https://bugs.eclipse.org/bugs/show_bug.cgi?id=277162
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238156
The data kept in the RemoteSystemsConnections project was moved from
the workspace to the metadata area when IBM contributed RSE to eclipse
project. There were locking problems associated with keeping it in the
workspace that would have forced several long running operations into
the foreground.
-- Dave Dykstal, IBM Rational Developer for Power Systems
Re: can't share, import/export RSE profiles [message #537854 is a reply to message #537852] Thu, 03 June 2010 16:54 Go to previous messageGo to next message
Thanks David! Looking forward to seeing more of these bugs/requests fulfilled.
Re: can't share, import/export RSE profiles [message #583382 is a reply to message #537852] Thu, 03 June 2010 16:54 Go to previous message
Previous Topic:can't share, import/export RSE profiles
Next Topic:RSE connection
Current Time: Wed Jul 23 10:49:40 EDT 2025
Powered by FUDForum. Page generated in 0.04333 seconds
