Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Validating an EMF model programatically
Validating an EMF model programatically [message #535839] Tue, 25 May 2010 19:23 Go to next message
Hi everyone, I posted this question a couple of days ago in the UML forum but it seems that I should have used the EMF newsgroup instead, so I'm just moving the message.
I was going over the EMF Validation Framework example and I was able to set everything up and add a few extra constraints. Then I run the plugin as an eclipse application, I create the model and then in the editor menu I can select validate to check the constraints and everything works fine.
But I was wondering if it is possible to validate a model programmatically, without using the editor.
// For example, create a few objects:
Book myBook = EXTLibraryFactory.eINSTANCE.createBook();
myBook.setTitle("EMF Validation");
Writer writer = EXTLibraryFactory.eINSTANCE.createWriter();
writer.setName("Hector");
//And then do the validation
I've been searching the web with no luck. Can something like this be done? I would appreciate any hints.
Thanks.
Re: Validating an EMF model programatically [message #535873 is a reply to message #535839] Wed, 26 May 2010 03:16 Go to previous messageGo to next message
it should work like this:
YourValidationClientSelector.setRunning(true);
IBatchValidator validator = (IBatchValidator)
ModelValidationService.getInstance().newValidator(Evaluation Mode.BATCH);
validator.setIncludeLiveConstraints(true);
IStatus status = validator.validate(object);
ValidationClientSelector.setRunning(false);
Furthermore I would look into the existing handler of the editor...
Cheers
Jonas
> fine.
> Thanks.
Re: Validating an EMF model programatically [message #535992 is a reply to message #535873] Wed, 26 May 2010 11:10 Go to previous messageGo to next message
Thanks Jonas,
I tried the that approach but it did not work in my example, I get an exception, this is the code I'm using:
University univ = UniversityFactory.eINSTANCE.createUniversity();
ValidationDelegateClientSelector.running = true;
IBatchValidator validator = (IBatchValidator)    ModelValidationService.getInstance().newValidator(EvaluationMode.BATCH);
IStatus status = validator.validate(univ);
ValidationDelegateClientSelector.running = false;
And the exception:
Exception in thread "main" java.lang.ExceptionInInitializerError
at emf.examples.university.validation.adapter.EValidatorAdapter . <init>(EValidatorAdapter.java:57)
at university.tests.Main.main(Main.java:23)
at org.eclipse.emf.validation.internal.EMFModelValidationPlugin .getPluginId(EMFModelValidationPlugin.java:201)
at org.eclipse.emf.validation.service.ModelValidationService.co nfigureConstraints(ModelValidationService.java:144)
at org.eclipse.emf.validation.service.ModelValidationService.<init >(ModelValidationService.java:134)
at org.eclipse.emf.validation.service.ModelValidationService.<clinit >(ModelValidationService.java:83)
... 2 more
Jonas wrote on Wed, 26 May 2010 03:16
Cheers
Jonas
Re: Validating an EMF model programatically [message #535999 is a reply to message #535992] Wed, 26 May 2010 11:26 Go to previous messageGo to next message
Hector,
Not all the frameworks support running stand alone. I think you'll need
to run this as an Eclipse application.
> Thanks Jonas,
> And the exception:
> at
> ... 2 more
>> Hi,
>> Mode.BATCH);
>> Cheers
>> Jonas
Re: Validating an EMF model programatically [message #536002 is a reply to message #535999] Wed, 26 May 2010 11:45 Go to previous message
I see, after searching for a while on the internet that seems to be the consensus. I'll see if I can find an alternative. Thanks for your help.
Hector
Ed Merks wrote on Wed, 26 May 2010 11:26
Hector,
> Thanks Jonas,
> And the exception:
> at
> ... 2 more
>> Hi,
>> Mode.BATCH);
>> Cheers
>> Jonas
Re: Validating an EMF model programatically [message #622938 is a reply to message #535873] Wed, 26 May 2010 11:10 Go to previous message
Thanks Jonas,
IBatchValidator validator = (IBatchValidator) ModelValidationService.getInstance().newValidator(Evaluation Mode.BATCH);
And the exception:
... 2 more
> Cheers
> Jonas
Re: Validating an EMF model programatically [message #622939 is a reply to message #622938] Wed, 26 May 2010 11:26 Go to previous message
Hector,
> Thanks Jonas,
> And the exception:
> at
> ... 2 more
>> Hi,
>> Mode.BATCH);
>> Cheers
>> Jonas
Re: Validating an EMF model programatically [message #622940 is a reply to message #535999] Wed, 26 May 2010 11:45 Go to previous message
Hector
> Hector,
> > Thanks Jonas,
> > And the exception:
> > at
> > ... 2 more
> >> Hi,
> >> Mode.BATCH);
> >> Cheers
> >> Jonas
Previous Topic:Class invoked when attribute value is changed
Next Topic:[Texo] not possible to define Embedded-id in orm
Current Time: Fri Jul 25 08:48:07 EDT 2025
Powered by FUDForum. Page generated in 0.07148 seconds
