Home » Modeling » TMF (Xtext) » Syntactic predicates in 0.8M4
Syntactic predicates in 0.8M4 [message #509390] Fri, 22 January 2010 01:02 Go to next message
Is support for syntactic predicates implemented in the 0.8M4 version of
Xtext ? I have read that it was part of the planned features for .8 but
I was wondering whether this is still the case (I need this feature for
adapting an ANTLR ANSI-C grammar).
Steven
Re: Syntactic predicates in 0.8M4 [message #509521 is a reply to message #509390] Fri, 22 January 2010 11:58 Go to previous messageGo to next message
I forgot the magic word : "thanks in advance,"
Steven Derrien a écrit :
> Steven
Re: Syntactic predicates in 0.8M4 [message #509665 is a reply to message #509390] Sun, 24 January 2010 05:00 Go to previous messageGo to next message
Hi Steven,
syntactic predicates are not yet supported nor is it a planned item (we
plan per milestone).
Could you outline what you want to solve. Many situations can be solved
with LL(*) and backtracking.
Sven
Steven Derrien schrieb:
> Steven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: Syntactic predicates in 0.8M4 [message #509674 is a reply to message #509665] Sun, 24 January 2010 10:41 Go to previous messageGo to next message
Hi Sven,
> Hi Steven,
I just wanted to get an idea of the required effort to adapt an exising
ANTLR C-ANSI grammar to Xtext. I set backtrack=true in MWE, there was no
error message, but my grammar is obviously not working/
BTW, If some people are interested by an C-ANSI Xtext parser, I'd be
glad to share my efforts.
Following is an excerpt of the an ANTLR C-ANSI grammar
(http://www.antlr.org/grammar/1153358328744/C.g) which uses predicates
to cope with declarator/definition ambiguity.
> /** Either a function definition or any other kind of C decl/def.
> * The LL(*) analysis algorithm fails to deal with this due to
> * recursion in the declarator rules. I'm putting in a
> * manual predicate here so that we don't backtrack over
> * the entire function. Further, you get a better error
> * as errors within the function itself don't make it fail
> * to predict that it's a function. Weird errors previously.
> * Remember: the goal is to avoid backtrack like the plague
> * because it makes debugging, actions, and errors harder.
> * Note that k=1 results in a much smaller predictor for the
> * fixed lookahead; k=2 made a few extra thousand lines. ;)
> * I'll have to optimize that in the future.
> external_declaration
> options {k=1;}
> : ( declaration_specifiers? declarator declaration* '{' )=> function_definition
> | declaration
Steven
Re: Syntactic predicates in 0.8M4 [message #509722 is a reply to message #509674] Mon, 25 January 2010 03:19 Go to previous messageGo to next message
>> * Note that k=1 results in a much smaller predictor for the *
>> options {k=1;}
>> function_definition
>> | declaration
That one should work with backtrack=true, since in that mode antlr works
like a packrat parser, which tries to match the alternatives in the
given order.
That is if function_definition matches (i.e there's a '{') it comsumes
it, else it tries to consume declaration.
Sven
Re: Syntactic predicates in 0.8M4 [message #535856 is a reply to message #509674] Tue, 25 May 2010 23:54 Go to previous messageGo to next message
-sorry I'm new to this forum, but I didn't found any way to send private message-
Hi Steven,
Is your ANTL C grammar adaptation to Xtext working well ?
I'll be really interested to see the result / sources ...
Pierrick
Re: Syntactic predicates in 0.8M4 [message #1007862 is a reply to message #509674] Thu, 07 February 2013 14:45 Go to previous message
Hi Setevn,
Could you please share? It would be really helpful, we are looking for an ANSI C xtext grammar as well.
Roza
Previous Topic:How do I make it so I can add decimals to the amount and quantity and also recieve a correct decimal
Next Topic:beginner question
Current Time: Sat Jul 26 02:58:25 EDT 2025
Powered by FUDForum. Page generated in 0.04702 seconds
