Home » Archived » Buckminster » Different eclipse.exe results in "eclipse executable launcher was unable to locate its companio
Different eclipse.exe results in "eclipse executable launcher was unable to locate its companio [message #535758] Tue, 25 May 2010 10:03 Go to next message
hi!
I'm not sure whether this is a buckminster issue in the first place, but here is our problem:
we set up a standard buckminster build and when we run it from within the IDE (installed buckminster is 1.1.350) we get a working output.
if we run the same build from our hudson server (installed buckminster is 1.2.360) we also get an output, but when we try to start the application we get the error "eclipse executable launcher was unable to locate its companion shared library". we noticed, that the eclipse.exe of that package has a different filesize compared to the eclipse.exe of the working output. if we simply replace it with the eclipse.exe from the working build of our local buckminster this application starts as well.
has anyone had this problem before?
regards,
Andreas
Re: Different eclipse.exe results in "eclipse executable launcher was unable to locate its comp [message #535768 is a reply to message #535758] Tue, 25 May 2010 10:28 Go to previous messageGo to next message
Hi Andreas,
is it possible that you have a different environent in the IDE than on
the build server (32/64 bit, different window system,...)?
If so, what environment settings are you using on the build system?
Johannes
Re: Different eclipse.exe results in "eclipse executable launcher was unable to locate its comp [message #535893 is a reply to message #535768] Wed, 26 May 2010 04:49 Go to previous messageGo to next message
Hi Johannes,
well, you're totally right. the buildserver is running a 32bit windows xp, while my working desktop machine is a 64bit windows xp.
but shouldn't it still work running the 32bit build in a 64bit environment?
regards,
Andreas
Re: Different eclipse.exe results in "eclipse executable launcher was unable to locate its comp [message #535907 is a reply to message #535893] Wed, 26 May 2010 05:56 Go to previous message
Hi Andreas,
Only in case you are using a 32 Bit VM on the 64 Bit system. Can you try
the build product on a 32 bit system to confirm if that is the cause?
If it works there, you should probably set the target.arch on the build
server to 64 Bit and give that a try.
Johannes
Previous Topic:How to hide org.eclipse.equinox.executable?
Next Topic:Buckminster questions about build practices
Current Time: Wed Jun 04 15:52:29 EDT 2025
Powered by FUDForum. Page generated in 0.04424 seconds
