Home » Language IDEs » PHP Development Tools (PDT) » How to set up Zend Debugger to run with URI imbedded parameter(Zend Debugger)
How to set up Zend Debugger to run with URI imbedded parameter [message #535511] Mon, 24 May 2010 04:07 Go to next message
We know that in ZF, all request are run through index.php file. Parameters can be passed as part as URI. For example:
http://localhost/index/about
will be interpreted as looking for Index Controller and AboutAction.
However, there isn't a file name index/about on the actual file directory.
My question is how do you run this URI through debugger.
What I do and is wrong is:
Debug Configrations -> set the php File as index.php/about
and run this as a PHP web page.
The result I get is as if I am running index.php. The system ignore the "/about" part of the URI.
Can someone tell me what's the right way of passing this parameter to the debugger?
Re: How to set up Zend Debugger to run with URI imbedded parameter [message #535628 is a reply to message #535511] Mon, 24 May 2010 22:02 Go to previous messageGo to next message
I wonder why you don't set 'URL' field in Configurations.
Uncheck 'Auto generate', then you can set "/index/about".
Re: How to set up Zend Debugger to run with URI imbedded parameter [message #535633 is a reply to message #535628] Mon, 24 May 2010 23:24 Go to previous message
Toshihiro Izumi wrote on Mon, 24 May 2010 22:02
Thank you for your help. It turns out that I shall configure as "PHP web page" instead of "PHP Script". It's a simple problem but trip me hard. Thank you for your reply.
Previous Topic:How to disable cache of build-in web browser
Next Topic:create PHP project
Current Time: Sat Aug 02 13:37:22 EDT 2025
Powered by FUDForum. Page generated in 0.03589 seconds
