Home » Eclipse Projects » Eclipse Platform » Sort in Project Explorer
Sort in Project Explorer [message #533287] Wed, 12 May 2010 20:03 Go to next message
since a few days the sort of the tree in my Project Explorer is only alphabetical instead of alphabetical folders before alphabetical files. It is realy annoying and I cannot find the option to change this back to my old sort order.
Can anyone tell me where to do this?
Markus
Re: Sort in Project Explorer [message #533688 is a reply to message #533287] Sat, 15 May 2010 12:28 Go to previous messageGo to next message
Do you mean the content of some projects? If so which projects?
You can look in the view menu (the little upside down triangle at the top right of the project explorer view) and go into Customize View... and then into the Conent tab and make sure the content that you want is enabled.
Re: Sort in Project Explorer [message #533709 is a reply to message #533688] Sat, 15 May 2010 15:46 Go to previous messageGo to next message
Everything which should be enabled is enabled.
http://wwwipr.ira.uka.de/~mehrwald/eclipse.png
On the image you can see what I mean. I want to have all folders together and all files which it was before. It is a web project as you can see.
Edit: Fixed URL of image
[Updated on: Sun, 16 May 2010 10:29] by Moderator
Re: Sort in Project Explorer [message #533710 is a reply to message #533709] Sat, 15 May 2010 15:49 Go to previous messageGo to next message
The link to your image does not seem to work.
Can you say which version of Eclipse and of the Webtools you are using?
Also, when and under which circumstances did it work before?
Re: Sort in Project Explorer [message #533743 is a reply to message #533287] Sun, 16 May 2010 10:33 Go to previous messageGo to next message
Hopefully the link to the image works now!
I use Eclipse 3.5.2 with WTP 3.1.1
It worked all time before and I cannot really say what I did that it happens, sorry!
Re: Sort in Project Explorer [message #535449 is a reply to message #533743] Sun, 23 May 2010 13:27 Go to previous messageGo to next message
I figered out now that the problem is cause by the Maven WTP integration. If I uninstall it, the order is as usual but I need it.
Does someone know why the Maven integration changes the normal behavier?
Re: Sort in Project Explorer [message #535461 is a reply to message #535449] Sun, 23 May 2010 15:12 Go to previous message
You should post your question about that on the Maven list.
They likely have an extension point that modifies the Project Explorer using the Common Navigator.
Previous Topic:[org.eclipse.team] shared projects recognition after project import
Next Topic:State of the ContentDescriptionManager Cache
Current Time: Sat Jul 26 18:50:06 EDT 2025
Powered by FUDForum. Page generated in 0.08249 seconds
