Home » Archived » M2M (model-to-model transformation) » Metamodel migration, how to ?
Metamodel migration, how to ? [message #535091] Fri, 21 May 2010 05:36 Go to next message
I have a big ecore metamodel(myMetaModelv1.ecore) that I refactored by changing a few inheritance and some class attributes and references (myMetaModelv2.ecore).
I am in the process of writing a migration engine for all the models conforming to the old metamodel, so I tought of using some M2M transformation.
I looked at the ATL transformation user guide and it seems that I need to create a copy of all the old model instance into the new model.
My problem is that most of the classes have not been renamed and still have the same attributes, the changes I have made just concern a small amount of classes.
I there any mean such as a ecore transformation/generation that could help me generate the atl script for the copy of the old instance to the new ones automatically ?
Is there another approach to take ?
Thanks for any lead.
SeB.
Re: Metamodel migration, how to ? [message #535114 is a reply to message #535091] Fri, 21 May 2010 06:40 Go to previous messageGo to next message
Have a look here (EModelCopyGenerator.atl).
Re: Metamodel migration, how to ? [message #535115 is a reply to message #535091] Fri, 21 May 2010 06:39 Go to previous messageGo to next message
Le 21/05/2010 11:36, seb.fr a écrit :
> Hello, I have a big ecore metamodel(myMetaModelv1.ecore) that I
> transformation.
> amount of classes.
> SeB.
You may use the ATL refining mode:
http://wiki.eclipse.org/ATL/User_Guide_-_Overview_of_the_Atl as_Transformation_Language#Refining_mode_execution_semantics
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: Metamodel migration, how to ? [message #535128 is a reply to message #535115] Fri, 21 May 2010 07:50 Go to previous messageGo to next message
I have tried one simple refining transformation which does nothing
-- @path MM=/org.talend.model/model/metadata.ecore
-- @path OLDMM=/org.talend.model.transformation/old_models/metadata.e core
module TosMetadata400to410;
create OUT : MM refining IN : OLDMM;
and the output gets empty which I understand because I do not know how the mapping would be done between the 2 model classes because althougth the have the same name and belong to the same package and almmost have the same attributes, the package names space URI have been change to reflect the change of version and I am affraid they are considered as completly different models.
How does ATL handle refining from one metamodel to another ?
Re: Metamodel migration, how to ? [message #535132 is a reply to message #535114] Fri, 21 May 2010 08:02 Go to previous messageGo to next message
Sylvain EVEILLARD wrote on Fri, 21 May 2010 06:40
Thank fo the tip, This seems to be what I am looking for althoug I am looking at Atlas Model Weaving also.
But I do not know how to use the given ATL, do you have any lead or tutorial on how to use the query the user guide is not sufficent.
Is there any book I could get have deeper information on ATL ?
Anyway thaks for this quick answer.
SeB.
Re: Metamodel migration, how to ? [message #535156 is a reply to message #535132] Fri, 21 May 2010 08:51 Go to previous messageGo to next message
seb.fr wrote on Fri, 21 May 2010 08:02
SeB.
A query is just a standard transformation but you only add input models. Here the input model is your metamodel conforming to ecore (be sure to use the 'isMetaMetaModel' checkbox).Be careful tho that with ATL v3, the writeTo helper is no longer relative to the workspace but to the eclipse installation folder instead (that is really puzzling I know). So, just use an absolute path.
Re: Metamodel migration, how to ? [message #535170 is a reply to message #535156] Fri, 21 May 2010 09:25 Go to previous message
Thanks, I manage to generate the copy.atl file from the script.
Now I'll try to make it work.
SeB.
Sylvain EVEILLARD wrote on Fri, 21 May 2010 08:51
SeB.
Previous Topic:UML2OWL transformation gives error
Next Topic:[ATL] empty Sequence
Current Time: Wed Jul 23 16:57:26 EDT 2025
Powered by FUDForum. Page generated in 0.05948 seconds
