Home » Language IDEs » AspectJ » BUG? Organize Imports on Intertype-Declaration complains "Compilation unit has parse errors&quo
BUG? Organize Imports on Intertype-Declaration complains "Compilation unit has parse errors&quo [message #534689] Wed, 19 May 2010 18:28 Go to next message
i have an aspect with an inter-type declaration, which looks like this:
package de.wieger.domaindriven.sample;
<lots of unused imports>
privileged aspect Person_ITD {
Person.new(PersonBuilder pBuilder) {
this();
If i invoke "Organize Imports" in eclipse, i get the following error:
"Compilation unit has parse errors: Constructor call must be the first statement in a constructor".
I'm using AJDT 2.0.2.
It looks like this is a bug. Is anybody else experiencing this?
Should i file a bug for this in bugzilla?
From my prospective, it seems like the method AjOrganizeImportsOperation#collectReferences is a little bit too strict about what should be considered as a relevant parsing error.
I have seen, that AjCompilationUnitProblemFinder filters a lot of problems like the one causing trouble when invoking "organize imports" out.
There is an explicit snippet, dealing with my problem:
if (numArgs == 0 && id == IProblem.InvalidExplicitConstructorCall) {
// ITD constructor making explicit this() call.
// lots of potential for false negatives
return false;
Maybe this could indicate the direction for a fix?
What do you think?
regards,
Thomas
Re: BUG? Organize Imports on Intertype-Declaration complains "Compilation unit has parse errors [message #534694 is a reply to message #534689] Wed, 19 May 2010 19:39 Go to previous messageGo to next message
This is most definitely a bug.
I think the solution is, as you say to use AJCompilationUnitProblemFinder to determine if this is a problem that we should be concerned about.
Could you please raise a bug for this? I expect that a fix is imminent.
Thanks for proposing a solution.
Re: BUG? Organize Imports on Intertype-Declaration complains "Compilation unit has parse errors [message #534968 is a reply to message #534694] Thu, 20 May 2010 16:17 Go to previous messageGo to next message
i have raised bug 313808 for this issue (https://bugs.eclipse.org/bugs/show_bug.cgi?id=313808).
Thomas
Re: BUG? Organize Imports on Intertype-Declaration complains "Compilation unit has parse errors [message #534997 is a reply to message #534968] Thu, 20 May 2010 19:50 Go to previous message
Thanks.
Previous Topic:How to call inherited methods with return values?
Next Topic:BUG? Organize Imports on Intertype-Declaration complains "Compilation unit has parse errors&
Current Time: Fri Jul 18 13:55:31 EDT 2025
Powered by FUDForum. Page generated in 0.04866 seconds
