Home » Archived » XML Schema Definition (XSD) » Delete an Element
Delete an Element [message #53231] Fri, 24 September 2004 19:52 Go to next message
Originally posted by: gj.puredge.com
I'm deleting an Element from an Abstract schema.
Assuming that XSDElementDeclaration "element" is not global, ie: it is
declared inside some other declaration I believe all I do is remove
the particle from the model group list:
XSDElementDeclaration element;
// Get the particle for this element
XSDParticle particle = (XSDComponent)element.getContainer();
// Get model group containing the particle
XSDModelGroup group = (XSDModelGroup)particle.getContainer();
// Remove the particle
group.getContents().remove(p);
I hope I got this one right. It seems to work okay but I'm worried I have
oversimplified this and forgotten something really important. Any comments?
Re: Delete an Element [message #53367 is a reply to message #53231] Mon, 27 September 2004 07:50 Go to previous messageGo to next message
Gary,
That should do the trick. EcoreUtil.remove will do the same thing.
Gary J wrote:
>Hi,
>Thanks
Re: Delete an Element [message #53446 is a reply to message #53367] Mon, 27 September 2004 14:13 Go to previous messageGo to next message
Wow! Just EcoreUtil.remove(object)? That would be very cool.
In my case I have a schema loaded into a simple tree model. I keep a
reference to the schema EObject that each tree node corresponds to:
Schema: reference to XSDSchema
Elements: reference to XSDElementDeclaration (resolved)
Attributes: reference to XSDAttributeUse
Model Groups: reference to XSDModelGroup
I just do an "instanceof" to know what kind of node I'm looking at and
display the proper icon.
Does this mean I could use EcoreUtil.remove(object) to delete each of these
from the XSD model?
EcoreUtil.remove(element);
I thought that the Particle containing the Element might get left behind.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cj8uio$717$2@eclipse.org...
Gary,
Gary J wrote:
>Hi,
comments?
>Thanks
Re: Delete an Element [message #53498 is a reply to message #53446] Mon, 27 September 2004 14:38 Go to previous message
--------------050004070004030008080504
Content-Type: text/plain; charset=us-ascii; format=flowed
Gary,
EcoreUtil.remove simply breaks the parent link. It will leave the
particle or attribute use behind.
>from the XSD model?
>Thanks
>Gary,
>Gary J wrote:
>>Hi,
>comments?
>>Thanks
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
EcoreUtil.remove simply breaks the parent link.&nbsp; It will leave the
particle or attribute use behind. <br>
<br>
<br>
Gary J wrote:
<blockquote cite="midcj9kvl$n9v$1@eclipse.org" type="cite">
<pre wrap="">Wow! Just EcoreUtil.remove(object)? That would be very cool.
from the XSD model?
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:cj8uio$717$2@eclipse.org">news:cj8uio$717$2@eclipse.org</a>...
Gary,
Gary J wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap=""><!---->comments?
</pre>
<pre wrap="">Thanks
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------050004070004030008080504--
Re: Delete an Element [message #591737 is a reply to message #53231] Mon, 27 September 2004 07:50 Go to previous message
Gary,
Gary J wrote:
>Hi,
>Thanks
Re: Delete an Element [message #591789 is a reply to message #53367] Mon, 27 September 2004 14:13 Go to previous message
from the XSD model?
Gary,
Gary J wrote:
>Hi,
comments?
>Thanks
Re: Delete an Element [message #591824 is a reply to message #53446] Mon, 27 September 2004 14:38 Go to previous message
Gary,
>from the XSD model?
>Thanks
>Gary,
>Gary J wrote:
>>Hi,
>comments?
>>Thanks
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
<br>
<br>
from the XSD model?
Gary,
Gary J wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</pre>
<pre wrap="">Thanks
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Previous Topic:Deteriming if an ElementDeclaration is a Simple or Complex Type
Next Topic:XSDSchema.resolveTypeDefinition on redefined schema
Current Time: Mon Sep 15 00:15:44 EDT 2025
Powered by FUDForum. Page generated in 0.08701 seconds
