Home » Archived » AMW » XML to Ecore Tranformation needed!
XML to Ecore Tranformation needed! [message #534879] Thu, 20 May 2010 10:34 Go to next message
Hi!
I hope, it's ok, that i post so many new topics here Smile
Now, I have all a need to start an ATL - Transformation (AMW - Level is done: - ATL-file generated).
BUT! Unfortunatelly is my input model - an xml-file.
And as far as I understand, it must be km3 or ecore (or xmi?), in order to include it in an ATL-transformation.
Please, could someone advise me, how to transform an xml to ecore or KM3 (or xmi)?
Thanks a lot!
Alexey
[Updated on: Thu, 20 May 2010 10:49] by Moderator
Re: XML to Ecore Tranformation needed! [message #534905 is a reply to message #534879] Thu, 20 May 2010 11:36 Go to previous messageGo to next message
You can use EMF directly (see here) or use the AM3 XML injector which will inject the xml file to a standard XML model (using the concepts of Nodes, Attributes, Texts, Root).
Re: XML to Ecore Tranformation needed! [message #536178 is a reply to message #534905] Thu, 27 May 2010 06:27 Go to previous message
Sylvain EVEILLARD wrote on Thu, 20 May 2010 11:36
Thank you! I will try the injector!
Previous Topic:QATL: "Model - extract to ATL" - option not found!
Next Topic:Eclipse 3.4.2 reads XMI 2.1 with errors!
Current Time: Sat Jul 26 08:44:08 EDT 2025
Powered by FUDForum. Page generated in 0.07956 seconds
