Home » Modeling » M2T (model-to-text transformation) » [Xpand] Adding files to ouput
[Xpand] Adding files to ouput [message #534265] Tue, 18 May 2010 10:26 Go to next message
is there a way to add files (or even better a directory) to the generated files ?
I have some files that are already written, and that I have to add to every generated code, and I want to add them to output.
How can I do that ?
Re: [Xpand] Adding files to ouput [message #534267 is a reply to message #534265] Tue, 18 May 2010 10:32 Go to previous messageGo to next message
Hi Maxime!
I'm not sure if I understand correct, but maybe the append flag for an outlet is what you are searching for. In the workflow generator component configuration add
<outlet path="..." name="APPEND_OUT" append="true"...
When you want to append something to a specific file use the FILE statement and name the APPEND_OUT outlet:
«FILE fileExp APPEND_OUT»
~Karsten
Re: [Xpand] Adding files to ouput [message #534273 is a reply to message #534265] Tue, 18 May 2010 10:42 Go to previous messageGo to next message
Sometimes I'm surprised as how quick people answer Smile
I generate JAVA code, and all my classes will extend an Entity class that is already written and set in stone.
I just want to have a copy of this file written with my generated files, so that I don't have to copy/paste it from explorer after generation.
(actually I have a few packages, not just one file)
Re: [Xpand] Adding files to ouput [message #534283 is a reply to message #534273] Tue, 18 May 2010 10:57 Go to previous messageGo to next message
Hello Maxime,
why don't you have a look at org.eclipse.emf.mwe.utils.FileCopy ?
Christian
Re: [Xpand] Adding files to ouput [message #534290 is a reply to message #534265] Tue, 18 May 2010 11:12 Go to previous messageGo to next message
That's what I need.
I just have to update to MWE 0.8
Thank you.
Re: [Xpand] Adding files to ouput [message #534431 is a reply to message #534265] Wed, 19 May 2010 03:50 Go to previous messageGo to next message
I have a noob question :s
I downloaded the emft-mwe-Update-0.8.0M5.zip (latest stable build), but I don't know how to install it.
I tried uninstalling MWE and copy/paste files from zip to eclipse directory, but doesn't work. So how can I install it ? Is there a site that I can add to add it using eclipse ?
maxime
EDIT : found how to install MWE 1.0, but i get an error when running my workflow files. Still searching.
[Updated on: Wed, 19 May 2010 05:18] by Moderator
Re: [Xpand] Adding files to ouput [message #534581 is a reply to message #534431] Wed, 19 May 2010 11:09 Go to previous messageGo to next message
The easiest way to install it is via update manager.
http://download.itemis.com/updates/milestones/
Sven
> Regards,
> maxime
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [Xpand] Adding files to ouput [message #534796 is a reply to message #534265] Thu, 20 May 2010 07:28 Go to previous messageGo to next message
Updated to new version, I have a problem with FileCopy.
workflow tells me file does not exist.
I tried pointing to my file following what I found there
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.xpand/doc/org.eclipse.xpand.doc/html/xpand_referenc e.html?root=Modeling_Project&view=co
So I get
	<component id="copier" class="org.eclipse.emf.mwe.utils.FileCopy"
		sourceFile="genCPP/src/fr/onera/gamme/pool/Entity.java"
		targetFile="genCPP/src-gen/myEntity/Entity.java"
Re: [Xpand] Adding files to ouput [message #534801 is a reply to message #534796] Thu, 20 May 2010 07:39 Go to previous messageGo to next message
Hello Maxime,
please note: "." is the root of the project you execute the workflow within so in your case
		sourceFile="../genCPP/src/fr/onera/gamme/pool/Entity.java"
		targetFile="../genCPP/src-gen/myEntity/Entity.java"
might be working (asuming genCPP is the project name)
AND: the target dir must exist.
~Christian
[Updated on: Thu, 20 May 2010 07:42] by Moderator
Re: [Xpand] Adding files to ouput [message #534802 is a reply to message #534265] Thu, 20 May 2010 07:55 Go to previous message
Thanks, works perfectly now.
Previous Topic:[Xpand] Versions of logging bundles for Xpand/Xtend in recent builds
Next Topic:[XPAND] Use multiple meta-models inside the same template
Current Time: Fri Jul 25 09:51:58 EDT 2025
Powered by FUDForum. Page generated in 0.05195 seconds
