| Re: How to show my dialog on top of Applet [message #534890 is a reply to message #534875] |
Thu, 20 May 2010 10:46   |
regarding integrating helper support for this could be discussed after
the 1.3 release. Maybe just post it to the dev list.
Regarding your 1) and 2) point: Instead of introducing a helper-service,
you could use display.addFilter( SWT.Activate, new Listener() {...}.
This should inform you when any shell is activated (either your own or
workbench shells).
Ben
Austin Riddle wrote:
> Hi Zezhenyan,
> To be a little more helpful, the first approach that we took was:
> 1) Provide a listener in our system that would be notified when any
> shell was opened.
> 2) Centralize the opening of shells in the system from a helper service
> that would notify the listeners after opening the shell. (This
> obviously does not work for shells that are opened from the workbench,
> so another option is to just override open() in Shell or Window to
> provide the notification.)
> 3) Register this new window listener for the module with the java applet.
> 4) Upon notification, have the listener overlay a tranparent IFrame on
> top of the plugin content.
> 5) When the window or shell is closed, remove the IFrame shim. (This
> can all be done from SWT and does not require any custom widget code.)
> The result is that the dialog can be moved freely on top of the plugin
> content.
> Drawbacks:
> For non-modal windows, the plugin content cannot be interacted with
> while the dialog is up.
> I would love to hear some other approaches from other people. It seems
> like there should be some RAP framework convenience for this. I would
> be happy to contribute a solution if we get some input from others on
> the RAP team.
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
FUDForum. Page generated in 0.05262 seconds
