Home » Modeling » M2T (model-to-text transformation) » [Xpand] How to indicate progress while executing a template ?
[Xpand] How to indicate progress while executing a template ? [message #533956] Mon, 17 May 2010 10:45 Go to next message
I want to show the progress of several generation steps in a ProgressMonitorDialog. In the standard java steps it is easy to do a monitor.worked(numberOfTicks).
Is it possible to give a similar feedback in the Xpand template code ?
With the following code I am able to run the the Xpand template, but I get no feedback for the progress view.
The generation is called from an IRunnableWithProgress:
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.SubProgressMonitor;
import org.eclipse.emf.mwe.core.monitor.ProgressMonitor;
import org.eclipse.emf.mwe.core.monitor.ProgressMonitorAdapter;
monitor.beginTask("Generating xxx", 10);
monitor.worked(1);
ProgressMonitor oawMonitor;
oawMonitor = new ProgressMonitorAdapter(new SubProgressMonitor(monitor, 5));
generateFiles(model, path, oawMonitor);
monitor.done();
The template is executed via XpandFacade:
public static void generateFiles(Model model, String path, ProgressMonitor monitor) {
   // configure outlet
   OutputImpl output = new OutputImpl();
   output.addOutlet(new Outlet(path));
   // create execution context
   XpandExecutionContextImpl execCtx = new XpandExecutionContextImpl(output, null);
   EmfRegistryMetaModel metamodel = new EmfRegistryMetaModel();
   execCtx.registerMetaModel(metamodel);
   execCtx.setMonitor(monitor);
   // generate
   XpandFacade facade = XpandFacade.create(execCtx);
   facade.evaluate("templates::simulation::Template_all::main", model);
Harald
Re: [Xpand] How to indicate progress while executing a template ? [message #534675 is a reply to message #533956] Wed, 19 May 2010 16:13 Go to previous messageGo to next message
Any idea ?
Is org.eclipse.emf.mwe.core.monitor.ProgressMonitor a possible approach ?
Re: [Xpand] How to indicate progress while executing a template ? [message #534729 is a reply to message #534675] Thu, 20 May 2010 03:27 Go to previous messageGo to next message
Harald M. schrieb:
> Any idea ?
You need to get access to the progress monitor, which could be done by
putting it into the global vars map in the execution context and then
later report progress using xtend.
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [Xpand] How to indicate progress while executing a template ? [message #535840 is a reply to message #534729] Tue, 25 May 2010 19:24 Go to previous messageGo to next message
Hi Sven,
the hint to report progress using xtend was very helpful.
Thank you.
In my solution I do not use a global vars map.
The execution context set with "execCtx.setMonitor(monitor)" is now accessable in Xtent.
In the online help I found the (new?) description to build an IExecutionContextAware Java extension.
In that Java extension I created some delegate methods
- MonitorSubTask(String name)
- MonitorWorked(int work)
that do the job... Smile
Harald
Re: [Xpand] How to indicate progress while executing a template ? [message #878120 is a reply to message #535840] Mon, 28 May 2012 11:38 Go to previous message
Harald M wrote on Wed, 26 May 2010 01:24
Hi Sven,
Thank you.
Harald
Hello Harald,
Can you post more information about your method to show progress during templates execution?
Thank you so much!
mrodrigo
Previous Topic:xtend2, UML2, MWE2
Next Topic:[xPand] Access OCL derivation during generation
Current Time: Wed Sep 24 08:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.04216 seconds
