Why is PDT 2 worse than PDT 1? [message #534598] |
Wed, 19 May 2010 11:47  |
I use eclipse PDT 1.x daily, and have done so for the last couple of years, when PDT2 first came out I was quick to upgrade and try it out.. Unfortunately I found the code hinting/assist to be much slower and inconsistent/unreliable most of the time, so i thought okay, must be a bad first release, and went back to PDT1 for the time being.
The other day, I decided to give PDT2 another chance and was once again annoyed to find its still horrendously slow with terrible code hinting/assist in comparison to PDT 1.. what gives?! It feels like Im using a different editor!
And Ive tried this on both my home and work pc, both of which should be more than capable of running it (AMD 64bit 4200x2, 2gig RAM). Im also pretty sure its not eclipse responsible, as ive run PDT 1 on the latest eclipse with no problems
Re: Why is PDT 2 worse than PDT 1? [message #537103 is a reply to message #534617] |
Tue, 01 June 2010 06:50  |
I was experiencing the same problems with docblocks:- delays and also function docblocks being doubly-nested and not picking up parameters.
Found it when moving from PDT1 to PDT2.2 to evaluate the changes in 2.2 -- but found the solution.
Removed my project from Eclipse (DON'T DELETE THE FILES); then deleted the .project and .buildpath files from the folder on the hard disk; then create a new project in PDT with the same name...
Ta da! Now works
FUDForum. Page generated in 0.06062 seconds
