Home » Archived » M2M (model-to-model transformation) » [ATL]
[ATL] [message #534580] Wed, 19 May 2010 11:17 Go to next message
Please i have a problem to transform the element type in my MM, the rule look like :
rule attribute {
name <- this.name,
type<-this.type.debug('type')
when i llok into the debug the elemnt is loaded but there is no binding so i solve the problem by using
do{
out.eSet(out.eClass().getEStructuralFeature('type'),
f.type);
any ideas on wwhy i got the problem?
mahmoud
Re: [ATL] [message #534583 is a reply to message #534580] Wed, 19 May 2010 11:26 Go to previous messageGo to next message
In the binding you're binding this.type and in the do section you're using f.type ?
Re: [ATL] [message #534597 is a reply to message #534583] Wed, 19 May 2010 11:47 Go to previous messageGo to next message
Hi, Soory, but this is my hole rule :
rule attribute {
from o : MM1l!Operation
to out : MMUML2!Operation (
name<-o.name,
visibility <- o.visibility,
do {
o.type);
and before i had this : type <- o.type
thanks
mahmoud
Re: [ATL] [message #534608 is a reply to message #534580] Wed, 19 May 2010 11:58 Go to previous messageGo to next message
type is a EReference ?
Re: [ATL] [message #534613 is a reply to message #534608] Wed, 19 May 2010 12:07 Go to previous messageGo to next message
Hi Sylvain,
Yes type is EReference.
thanks
mahmoud
Re: [ATL] [message #534614 is a reply to message #534580] Wed, 19 May 2010 12:08 Go to previous messageGo to next message
and how are the elements referenced transformed ?
Re: [ATL] [message #534622 is a reply to message #534614] Wed, 19 May 2010 12:17 Go to previous message
I got the idea normallay by using an other transformation to transform from type to another stuff, but i forget this
type <- o.type.getCorrespondingDataType() //a helper that return a type
mahmoud
Previous Topic:[QVTo] Problems using the "resolve/resolveone" command - tracking objects
Next Topic:[QVTO] simple mapping constructs
Current Time: Fri Jul 18 10:20:15 EDT 2025
Powered by FUDForum. Page generated in 0.04321 seconds
