Home » Eclipse Projects » Virgo » Build Virgo
Build Virgo [message #534350] Tue, 18 May 2010 14:46 Go to next message
Hi Virgo-Team!
I am very interessted in testing Virgo!!!!
I am trying to build virgo on my windows system, but build fails:-(!
BUILD FAILED
D:\virgo\org.eclipse.virgo.kernel\virgo-build\multi-bundle\a rtifact.xml:57:
The
following error occurred while executing this line:
D:\virgo\org.eclipse.virgo.kernel\virgo-build\multi-bundle\c ommon.xml:83:
The fo
D:\virgo\org.eclipse.virgo.kernel\virgo-build\common\artifac t.xml:54:
impossible
to publish artifacts for
org.eclipse.virgo.kernel#org.eclipse.virgo.kernel.shut
down;working@grznae368xp: java.io.FileNotFoundException:
rgo.kernel\org.eclipse.virgo.kernel.shutdown\..\integration- repo\org.eclipse.vir
go.kernel\org.eclipse.virgo.kernel.shutdown\2.1.0.BUILD-2010 0518184347.part\org.
eclipse.virgo.kernel.shutdown-2.1.0.BUILD-20100518184347.jar .sha1 (The
filename,
directory name, or volume label syntax is incorrect)
Total time: 4 seconds
D:\virgo\org.eclipse.virgo.kernel\build-kernel>java -version
I am using:
java version "1.6.0_11"
Java(TM) SE Runtime Environment (build 1.6.0_11-b03)
Java HotSpot(TM) Client VM (build 11.0-b16, mixed mode, sharing)
D:\virgo\org.eclipse.virgo.kernel\build-kernel>ant -version
Apache Ant version 1.7.1 compiled on June 27 2008
Please, can you give me a hint?!
Thanks a lot
Chris
Re: Build Virgo [message #534433 is a reply to message #534350] Wed, 19 May 2010 04:04 Go to previous messageGo to next message
I'm not sure if anyone has built Virgo on Windows, but I would guess this is a basic problem with the "D:\" start of the path to the integration repo where built artifacts are placed during the build.
We'll look into it and get back to you soon as we certainly don't want to prevent Windows users from building Virgo.
Re: Build Virgo [message #534546 is a reply to message #534350] Wed, 19 May 2010 09:50 Go to previous messageGo to next message
I need to have a go at recreating this, I can see that you are in the Kernel repo, could you tell me what ant command you are calling?
Thanks.
Re: Build Virgo [message #534636 is a reply to message #534546] Wed, 19 May 2010 13:05 Go to previous messageGo to next message
Thanks for your fast reply.
I am using the procedure at:
http://wiki.eclipse.org/Virgo
Thanks a lot
Chris
Christopher Frost schrieb:
> Thanks.
Re: Build Virgo [message #535215 is a reply to message #534636] Fri, 21 May 2010 11:22 Go to previous messageGo to next message
1st, I've learnt I have to manually subscribe to forum posts, I don't automatically notified of new posts, so sorry for the delay.
2nd, it's nothing obvious so I need to go and run the build which I will do next week. Hopefully I'll be able to see what is happening then. If it's an issue with our stuff I'll ask you to raise a bug and we will get on it.
Thanks for getting back to us,
Chris
Re: Build Virgo [message #536540 is a reply to message #534350] Fri, 28 May 2010 11:49 Go to previous messageGo to next message
I have tried this several times now and have it building fine but the tests are failing to start in the userigion. The cause will be Windows specific as it works on other platforms. We need to raise a JIRA issue to address this issue, I would be very grateful if you could do this and then it will get the proper attention. In the mean time you can try dm Server 2.0.2, it is functionally equivalent (http://www.springsource.org/dmserver).
Virgo Bugzilla
Chris
[Updated on: Fri, 28 May 2010 11:50] by Moderator
Re: Build Virgo [message #536672 is a reply to message #534350] Sat, 29 May 2010 12:33 Go to previous messageGo to next message
I had built Virgo on Windows without any problems (Java 1.6.0_16, Ant 1.7.1).
Kernel is started successfully with time beetween "KE0001I Kernel starting" and "UR0001I User region ready" approximately 25 sec.
Next library bundles (about 50) from production dm Server (running on RHE Linux) which includes: oracle.jdbc, apache.xerces, apache.cxf, org.mortbay.jetty.server etc. deployed on Virgo through plan without any errors.
After that I properly installed service bundles which includes database pools for two Oracle RAC (cluster) databases, integration services toward web services on third party platforms and web services on embedded jetty server.
So that everything works nicely on Windows like on Linux Smile
Veso
P.S.
There's still problems with attached files.
  • Attachment: log.log.txt
    (Size: 8.24KB, Downloaded 559 times)
[Updated on: Sat, 29 May 2010 13:24] by Moderator
Re: Build Virgo [message #537078 is a reply to message #536672] Tue, 01 June 2010 05:14 Go to previous messageGo to next message
It's good to hear it's all working for you. I've tried downloading the file a few times and every time it looks like a copy of some HTML source from the Eclipse forums. I take it this isn't what you meant to attach.
Chris.
Re: Build Virgo [message #537106 is a reply to message #537078] Tue, 01 June 2010 07:04 Go to previous messageGo to next message
Hi Chris,
Working perfectly Smile
There was the same problem with VirgoProjectCreationReview PDF file in post Draft docuware for Virgo creation review. Someone should check this issue with eclipse staff.
I'll put kernel log in code tags. Hope that will be properly viewable.
Veso
[2010-05-29 17:28:32.499] startup-tracker              org.eclipse.virgo.medic.eventlog.default                         KE0001I Kernel starting.
[2010-05-29 17:28:40.624] service-monitor-thread-1     org.eclipse.virgo.medic.eventlog.default                         KE0100W Reference '&deployer' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer)'.
[2010-05-29 17:28:40.890] service-monitor-thread-1     org.eclipse.virgo.medic.eventlog.default                         KE0100W Reference '&objectNameCreator' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.model.management.RuntimeArtifactModelObjectNameCreator)'.
[2010-05-29 17:28:40.890] service-monitor-thread-1     org.eclipse.virgo.medic.eventlog.default                         KE0100W Reference '&runtimeArtifactModel' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.model.RuntimeArtifactModel)'.
[2010-05-29 17:28:40.952] service-monitor-thread-1     org.eclipse.virgo.medic.eventlog.default                         KE0100W Reference '&applicationDeployer' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer)'.
[2010-05-29 17:28:41.562] Thread-3                     org.eclipse.virgo.medic.eventlog.default                         KE0101I Reference '&applicationDeployer' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer)'.
[2010-05-29 17:28:41.577] Thread-3                     org.eclipse.virgo.medic.eventlog.default                         KE0101I Reference '&deployer' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer)'.
[2010-05-29 17:28:42.890] Thread-3                     org.eclipse.virgo.medic.eventlog.default                         KE0101I Reference '&runtimeArtifactModel' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.model.RuntimeArtifactModel)'.
[2010-05-29 17:28:43.546] Thread-3                     org.eclipse.virgo.medic.eventlog.default                         KE0101I Reference '&objectNameCreator' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.model.management.RuntimeArtifactModelObjectNameCreator)'.
[2010-05-29 17:28:44.249] kernel-dm-11                 org.eclipse.virgo.medic.eventlog.default                         SH0001I Kernel ssh shell available on port 2401.
[2010-05-29 17:28:44.452] startup-tracker              org.eclipse.virgo.medic.eventlog.default                         KE0002I Kernel started.
[2010-05-29 17:28:44.671] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-05-29 17:28:47.390] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-05-29 17:28:48.202] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-05-29 17:28:48.405] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-05-29 17:28:48.546] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:48.624] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:55.671] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-05-29 17:28:55.686] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-05-29 17:28:55.702] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-05-29 17:28:55.718] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:55.733] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:55.733] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-05-29 17:28:55.811] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-05-29 17:28:55.827] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-05-29 17:28:55.874] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-05-29 17:28:55.889] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-05-29 17:28:57.499] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-05-29 17:28:57.530] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-05-29 17:28:57.530] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:57.577] start-signalling-2           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-05-29 17:28:57.608] start-signalling-2           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:57.639] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:57.905] start-signalling-2           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:57.905] start-signalling-2           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-05-29 17:28:57.936] Thread-2                     org.eclipse.virgo.medic.eventlog.default                         UR0001I User region ready.
[Updated on: Tue, 01 June 2010 07:04] by Moderator
Re: Build Virgo [message #537109 is a reply to message #537106] Tue, 01 June 2010 07:15 Go to previous messageGo to next message
Thanks for that. The 'waiting for reference' messages coming out at the start are simply the result of the machine it's running on being a little slow, just warnings so nothing to worry about. Our dev machines are quite fast so we could of set the limits a little to eager. I think if you are getting this on production equipment it would be worth raising a bug getting us to move the limits back a little.
Thanks, Chris.
Re: Build Virgo [message #537251 is a reply to message #537109] Tue, 01 June 2010 12:49 Go to previous messageGo to next message
Hi Chris,
It's log from my desktop win machine (Win XP, Pentium 4, 2GB) where besides kernel at same time running STS, Tomcat, Firefox, Outlook and several applications and corporate policy services (PF usage 1.5 GB approx.). So, when I turned off some of these apps, 'waiting for reference' messages disappeared.
Log from WinXP (PF usage 750 MB)
[2010-06-01 14:09:54.334] startup-tracker              org.eclipse.virgo.medic.eventlog.default                         KE0001I Kernel starting.
[2010-06-01 14:10:02.412] kernel-dm-11                 org.eclipse.virgo.medic.eventlog.default                         SH0001I Kernel ssh shell available on port 2401.
[2010-06-01 14:10:02.583] startup-tracker              org.eclipse.virgo.medic.eventlog.default                         KE0002I Kernel started.
[2010-06-01 14:10:02.740] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:03.990] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:04.443] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:04.583] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:04.708] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:04.771] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:10.302] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:10.318] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:10.318] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:10.333] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:10.349] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:10.349] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:10.412] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:10.427] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:10.458] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:10.474] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:11.505] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:11.505] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:11.537] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.552] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:11.583] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.583] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.724] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.740] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:11.755] Thread-2                     org.eclipse.virgo.medic.eventlog.default                         UR0001I User region ready.
In addition, I have checked on Linux production machine (RH Enterprise 5, 4GB, dual-core).
Kernel started twice faster than on Win machine without 'waiting' messages.
I used same win build (of course after converted bin scripts in unix format).
Log from RHE 5
[2010-06-01 17:44:33.689] startup-tracker              org.eclipse.virgo.medic.eventlog.default                         KE0001I Kernel starting.
[2010-06-01 17:44:38.537] kernel-dm-11                 org.eclipse.virgo.medic.eventlog.default                         SH0001I Kernel ssh shell available on port 2401.
[2010-06-01 17:44:38.636] startup-tracker              org.eclipse.virgo.medic.eventlog.default                         KE0002I Kernel started.
[2010-06-01 17:44:38.750] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:38.843] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:38.879] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:38.900] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:38.918] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:38.934] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0000I Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:39.877] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:39.882] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:39.886] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:39.891] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:39.896] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:39.901] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0001I Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:39.932] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:39.941] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:39.951] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:39.951] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:40.388] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:40.394] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:40.404] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:40.404] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.424] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.427] system-artifacts             org.eclipse.virgo.medic.eventlog.default                         DE0004I Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.557] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.563] start-signalling-1           org.eclipse.virgo.medic.eventlog.default                         DE0005I Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:40.570] Thread-2                     org.eclipse.virgo.medic.eventlog.default                         UR0001I User region ready.
Veso
Re: Build Virgo [message #537365 is a reply to message #537251] Wed, 02 June 2010 04:25 Go to previous messageGo to next message
Thanks for letting us know. It's good to know they go away on that hardware, they really should. This is useful to know.
Chris.
Re: Build Virgo [message #577056 is a reply to message #534350] Wed, 19 May 2010 04:04 Go to previous messageGo to next message
Re: Build Virgo [message #577073 is a reply to message #534350] Wed, 19 May 2010 09:50 Go to previous messageGo to next message
Thanks.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: Build Virgo [message #577088 is a reply to message #534546] Wed, 19 May 2010 13:05 Go to previous messageGo to next message
Thanks a lot
Chris
> Thanks.
Re: Build Virgo [message #577120 is a reply to message #534636] Fri, 21 May 2010 11:22 Go to previous messageGo to next message
Chris
Re: Build Virgo [message #577179 is a reply to message #534350] Fri, 28 May 2010 11:49 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/buglist.cgi?query_format=advan ced;order=Importance;classification=RT;product=Virgo
Chris
Re: Build Virgo [message #579040 is a reply to message #534350] Sat, 29 May 2010 12:33 Go to previous messageGo to next message
So that everything works nicely on Windows like on Linux :)
    (Size: 8.24KB, Downloaded 298 times)
Re: Build Virgo [message #579092 is a reply to message #579040] Tue, 01 June 2010 05:14 Go to previous messageGo to next message
Chris.
Re: Build Virgo [message #579123 is a reply to message #579092] Tue, 01 June 2010 07:04 Go to previous messageGo to next message
Hi Chris,
Working perfectly :)
[2010-05-29 17:28:40.624] service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&deployer' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.Applica tionDeployer)'.
[2010-05-29 17:28:40.890] service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&objectNameCreator' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.model.management.Runt imeArtifactModelObjectNameCreator)'.
[2010-05-29 17:28:40.890] service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&runtimeArtifactModel' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.model.Runtim eArtifactModel)'.
[2010-05-29 17:28:40.952] service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&applicationDeployer' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.Applica tionDeployer)'.
[2010-05-29 17:28:41.562] Thread-3 org.eclipse.virgo.medic.eventlog.default KE0101I Reference '&applicationDeployer' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.Applica tionDeployer)'.
[2010-05-29 17:28:41.577] Thread-3 org.eclipse.virgo.medic.eventlog.default KE0101I Reference '&deployer' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.Applica tionDeployer)'.
[2010-05-29 17:28:42.890] Thread-3 org.eclipse.virgo.medic.eventlog.default KE0101I Reference '&runtimeArtifactModel' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.model.Runtim eArtifactModel)'.
[2010-05-29 17:28:43.546] Thread-3 org.eclipse.virgo.medic.eventlog.default KE0101I Reference '&objectNameCreator' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.model.management.Runt imeArtifactModelObjectNameCreator)'.
Re: Build Virgo [message #579138 is a reply to message #579123] Tue, 01 June 2010 07:15 Go to previous messageGo to next message
Thanks, Chris.
Re: Build Virgo [message #579159 is a reply to message #537109] Tue, 01 June 2010 12:49 Go to previous messageGo to next message
Hi Chris,
Log from RHE 5
Veso
Re: Build Virgo [message #579180 is a reply to message #537251] Wed, 02 June 2010 04:25 Go to previous message
Chris.
Previous Topic:Deployment order based on the artifact type
Next Topic:Speeding up resolution and server start up
Current Time: Wed Jul 23 12:40:48 EDT 2025
Powered by FUDForum. Page generated in 1.77210 seconds
